finally dyno tuned :) graph picture
ok so i finally got my car back today like all of you stated with heads and cams on stock bottem end the tuner didnt want to give me such a harsh tune he said it wasnt even a mild tune he left it as baby as possible so i dont blow up my motor and even then he said i can still blow it if i pound on it too much im satisfied with what it made in the next couple of months i should be getting my built block in and switching pullies for a 15 pounds of boost
http://i128.photobucket.com/albums/p...untitled-3.jpg
pics of your car on the dyno??? thatd help prove your stories to us. 0949er, have you seen the previous threads from him? he's been trolling for a while now.
That makes peak power kinda low... Especally for a heads cam car.... with a centrifugal blower.
N/A with Stage 1 cams my car made peak power at around 58-5900 and a Centrifugal blower usually pushes up the top end more. I would expect you to be making peak power around 6000 or higher.
0949er Where does your car peak out? Around 6200 I'd guess, right?
EDIT: I also just noticed the dyno numbers Are STD which means they are inflated a little, SAE always reads a few hp less. I just figured I'd toss that int there too.
i have a procharger d-1 blower in it with 3 core intercooler and yes i have a picture of it on the dyno i also will show you the recipt of the shop if you guys want but tomorrow cause im leaving my house right about now
NA with Stage 1 cams my car made peak power at around 58-5900 and a Centrifugal blower usually pushes up the top end more. I would expect you to be making peak power around 6000 or higher.
i want to wipe my *** with this thread. I might as well use that dyno sheet as toilet paper. thanks!
