Solid Motor Mounts and stock Transmission mount
Old 10-20-2010, 08:50 PM
MineralGrey
MineralGrey's Avatar
Default Solid Motor Mounts and stock Transmission mount
Basically what i said up here^. Is it ok to run solid motor mounts with the stock Transmission mount? How is the ride quality? a lot of vibrations?
I used to have polyurethane mounts in my old car and it rattled pretty badly at idle but I have read the solids aren't that bad???.
MineralGrey is offline
Old 10-21-2010, 05:50 AM
uberstang1
Chupacabra
uberstang1's Avatar
Never personally ran solids, but I'm currently runnin poly motor and a stock trans and I get a good amount of vibration but its not unbearable. With solids I would think bolts would be rattling loose lol.
uberstang1 is offline
Old 10-21-2010, 07:18 AM
oxfordgt
oxfordgt's Avatar
I ran solid motor mounts and not a single rattle or vibration and nothing came loose.
oxfordgt is offline
Old 10-21-2010, 06:13 PM
MineralGrey
really? so the cabin didn't shake at all? which company did you go with?
Old 10-21-2010, 06:38 PM
oxfordgt
oxfordgt's Avatar
I'm sure the car would have shook more if I would have had different suspension but no vibrations. I got some cheapo ones off ebay, no clue who made them.
oxfordgt is offline
Old 10-22-2010, 06:01 AM
uberstang1
Chupacabra
uberstang1's Avatar
I'm sorry but there is absolutly no way you can run solid motor mounts and not notice any difference or vibration over stock.
Old 10-22-2010, 07:28 AM
oxfordgt
oxfordgt's Avatar
Have you ever ran them?
When I had poly mounts I had a vibration at 180rpms but it all went away when I went to solid.
oxfordgt is offline
Old 10-22-2010, 08:18 AM
school boy
school boy's Avatar
what about solids with running a teksid aluminum block? sorry op for the thread jacking
school boy is offline
Old 10-22-2010, 08:35 AM
MineralGrey
180 rpms?
its fine, I would imagine it would be fine that block is pretty strong.
Old 10-22-2010, 08:46 AM
school boy
school boy's Avatar
i was thinking the same thing but me going to a teksid block build next year i rather be safe since it will be a 3500+ short block
i think he meant 1800 rpm
Quick Reply: Solid Motor Mounts and stock Transmission mount
