Need help with plumbing fuel system on 99 GT
I have 24lb Ford Racing injectors. Edelbrock manifold. And Edelbrock fuel rails. I don't want to run the stock lines, but I have NO IDEA what I'm supposed to get from here.
Is there a kit out there? Or are there some things I should look at? Do I need to look into a new fuel pump? Maybe fuel regulator?
Need to know what your power level is going to be and if you are going FI. But since you don't have much for mods there is no reason to change the lines.
+1 change the comp gears out before you have to buy a new engine.
Here is exactly what i just bought. You will need all this plus an adapter that will hook onto the stock fuel hat line. Took me a while to figure this all out lol. Once you see pics of all the parts you'll understand where they all go...hopefully.
SUM-220788B -8 TWIST-TITE HOSE 20FT BLACK $49.95
SUM-220831B -8 PLUG O-RING BLK $2.95
SUM-220846B 8AN TO 3/8 NPT ADAPTER $2.95
SUM-220890B -8 STRAIGHT BLACK HOSE END $6.95 (need 3 of these)
SUM-240116B 90 HOSE END -8AN 3/8 NPT $16.95 (need 3 of these)
TFS-23001 FUEL FILTER 8 AN 40 MICRON $34.95
TFS-5188000S FUEL PRESSURE SENSOR ADAPTER $45.95
09-16-2015 07:53 PM
09-10-2015 08:39 PM
