question about changing pulleys on s/c
i have a vortech s-trim with the stock pulley, that will be getting installed on my car here shortly. i will be swapping to a 3.33 6 rib pulley and i have a question. when going to a 6 rib pulley do you have to change out any other pulleys on your mustang? all my other pulleys on my car are stock. i am deployed right now and i can not look at the pulleys on my car to see and also i don't have enough time to search for the answer on the web. thanks for the help
Stock pullies are 6 rib. Converting the s trim to 6 rib means you're going to run the charger off the accessory belt, that is all.
If memory serves me correct, the only way to run an 8 rib would be to change all the pullies over to pullies off of a truck engine.
he's saying if you're going to a smaller pulley (u ddint mention ur current pulley size) u might need a smaller belt - since u asked about what else you might need to change.
in my first post i said that i had the stock pulley that comes on a vortech supercharger, i mentioned that i am going to a smaller pulley but that had nothing to do with my question. maybe i should of made the question more clear for yall, my question is right now i have a 4 rib pulley, i am upgrading to a 3.33 pulley and want to go with a 6 rib pulley, now switching from a 4 rib to 6 rib do you need to switch out any other pulleys that are on the car?
No. Converting the vortech to a 6 rib means that it will work with the stock pullies on the car. You will need to buy a longer belt than the stock sized one though, because you're adding 2 idlers and the blower to the same belt..
I actually had to go through this today with my pulley. Origionally you were saying you want to go with a smaller pulley, which from stock 3.33 down to something like 2.95 or even 2.90 is still 5 steps down from your current setup, which could possibly require you to buy a new crank pulley as well. I would give vortech a call @1-805-247-0226 and talk to them about it. Also, going from a 4 rib to a 6 rib would definately require you to buy a new crank pulley as well. Even if you didn't go from 4 to 6, you would have to buy a new belt if you got a smaller pulley (to up boost) to avoid the engine from screaming at you :\
no you don't need to change out any other pulleys. just swap out the new pulley on the vortech and u will need a smaller belt. don't quote me on this but i think stock 3.60 pulley belt size is 108". so what u can do is do some math with your free time over there becuase i know your just sitting on the FOB problably doing nothing lol.
