Last edit by: IB Advertising
Browse all: Brake Guides
- Ford Mustang Gt 1996 to 2004: Why is ABS Light On?
Guide to diagnose trouble and recommended solutions
ABS light on.
ABS light on.
on my 01 GT, the ABS light is always on, the ABS absolutely doesnt work, and the trac-0ff light is always lit, and also..definetly doesnt work.
I dont have a scanner yet, if I take the car ot Auto-Zone, will their free scan tool explain what needs to be replaced? Like wheel sensor, tone ring, something?
Before we get too far ahead of ourselves here, TOMMY.... do you run different diameter tires between front/rear? If they are not all OEM size, please give us the sizes of front/rear (all three numbers please)
Some issues can come up via differential sized tires.
Jazzer
Jazzer
Jazzer
Jazzer
Stock size tires front and rear, I think its 245/40ZR17
i actually had my ABS light turn on and traction control button trigger showing that traction control was off when i went on the highway the other day, i have 265/35/18 in front and 365/40/18 on the rear with 3.73 gears...i figured the tire size triggered a sensor because the ABS light and trac control button both turned off the next time i started the car
