Car is getting slower in 1/4
#32
#33
Hitting an IRS with a launch on a slick is like launching an IRS car with an auto in it. There is not a hard shock like there would be a drag radial.
Roots in JDM has nothing to do with this at all. Just because the example I gave is off of SVTP, and from a well known, well respected member, doesnt discredit it whatsoever. I have plenty of friends that run slicks on their IRS cars with stock shafts and they have no issues at all.
But just because your friends snap their shafts and mine dont really doesnt give any info towards whether its going to hurt or help. Just gives some examples of what can happen. There is no use us arguing about this because we both know that the other side is not going to give up on their argument. So I'm just going to agree to disagree.
But I will say this...I was not thinking about softer launching. I figured if he wanted to come off as hard as possible, slicks without a doubt. But soft launching and just trying to manage spin, drag radials will work fine.
Also, as far as splines go, 99 had 28 spline inner and 28 spline hubs. 01's had 28 spline inners and 31 spline hubs, 03/04 had 31 spline inner and hubs.
And turbo232, the guy is running stock 6 speed and stock IRS minus the bushings and shock/spring setup that ran in the 9's.
#34
Yes there will be no end to the argument (PS your friend I met with the terminator was swapping his IRS for a solid....lol), moving on. Teej did you even run your mustang at the track? This way you can have a comparision to whether or not the slick is to much tire to be beneficial with your setup because thats gonna be the next trial to wether or not its going to be worth it and this I am curious to because I don't know anyone running a slick on an IRS other than 400rwhp cobras.
#35
I would definately agree with Uber, although the sidewall does absorb some of that shock, the extra traction from a slick far outweighs that. An auto car could have much more horsepower but it is a relatively less violent launch than a stick car. And also depends a lot on the clutch in the 5 spd cars, a stock clutch will slip quite a bit on launch and lessen the driveline shock. A modified higher performance car is likely to have a heavier duty clutch that does not slip.
Just my thoughts, not trying to continue the argument.
#36
I say uberstang wins the argument because he managed to use a sentence with 61 words in it.
Seriously though, there are many varaibles that can effect how much stress a half shaft is expopsed to. OP's situation is probably not going to break a half shaft either way. It sounds to me like he would still be prefectly fine to run some ET Streets, but that is up to him to decide.
If I were OP, I would try to borrow a set of DRs for a pass or two. Then he'll see how much difference they make for him, and he can then decide what he wants to do from there.
#37
Do not run drag radials on your IRS! If anything find an extra 2 v6 wheels and throw some slicks on them if you want to run. IRS+DR's=broken half shafts every time.
Back to the issue at hand. I think its all in the 60' and the spinning after shifts thats hurting you. Spinning will add MPH but hurt ET. Its been proven many times. Also, clutch slipping is probably the reason for the slower 60'. Plus tires could have been "newer" and bit better back 2 years ago. Overall, I think your car is still performing the same, just the clutch might have seen its better days and the tires might not be as grippy as they were. Track prep too is also a concern to check into.
#38
And to address the most recent comment, its the initial shock that the slick helps tremendously with. The immediate shock that the drag radial would absorb, seeing that its a radial construction, will snap back, which is what causes the snapping of the halfshaft. Now when you step up to the slick it does not snap back and absorbs a lot off the energy of the hard launch.
But I have not run my car at the track. Hope to either get an IRS brace or diff cover as I have a slight leak from the current stock cover. One step at a time.
#39
That car has never seen traction before 3rd gear in its life. Never even seen drag radials. Most of my friends that drive mustangs are actually cobra owners. Some solid axle and some IRS. I'm probably going to be grabbing some 4.10's and a 28x10.5x17 Hoosier QTP's to run at the drag strip, and a Centerforce DF clutch sometime in the future. Then we'll see what a 230rwhp car with 4.10's and an IRS on slicks will do...that weighs 4000lbs. lol
#40
Or the heated super sticky slick wheel hops on the IRS and its game over half shaft. Teej I'm really not trying to bust your ***** on this but for NEVER running your car at the drag strip you really seem to be sure how its going to react and keep trying to talk how the IRS with the slick is gonna work at the track, just alot of talk when you never even had the IRS on the track with a street tire or a DR. As far as the car never seeing traction before 3rd gear.......the street and a prepped track cannot even be remotley compared in any way shape or form.
There is plenty of info over on SVTP on slicks versus drag radials and all of the tire and suspension guru's will agree with me that on an IRS car, slicks offer less chance of breakage and harder launches.
