Had a thought...Cheap and easy 3.73 gear install idea for the 8.8" SRA
I could do that, but why spend the time ripping it out of the ex, and put in used gears when I can have new and no labor for 100 more? The part I was trying to avoid was the shimming and all that because I have heard of stories where people can't get it right.
Anyone that cannot get the pinion depth and backspacing right should not be doing the job in the first place--it's not difficult, it just requires attention to detail and a bit of math...
Here is one of the better tutorials I've seen...
This is emphatically NOT so, the carrier shims are there because each differential case is dimensionally slightly different, as is each installed pinion's depth and relationship to the carrier bearing bosses once installed. The carrier shims are the last bit of adjustment to ensure proper contact of the pinion and ring gears.
One could perhaps get lucky and find that the shims as used the the donor or destination housings allowed proper backlash and contact pattern--however that would be a long shot...
