Changing Oil When Lowered
Old 10-22-2011, 10:13 AM
JRad405
JRad405's Avatar
Default Changing Oil When Lowered
I know most guys here are lowered. So how do you all change your oil? I mean I used to drive up my ramps and that's definitely not happening anymore.
Did you guys build your own ramps or are you guys just putting a jack under one area and lifting the car?
JRad405 is offline
Old 10-22-2011, 10:23 AM
Moonshine
Moonshine's Avatar
Place a jack under the car. Lift the car. Change the oil.
Moonshine is offline
Old 10-22-2011, 10:24 AM
uberstang1
Chupacabra
uberstang1's Avatar
+1 lol
uberstang1 is offline
Old 10-22-2011, 10:25 AM
arabianobsession
arabianobsession's Avatar
I know a couple of guys that use 2x4's to slowly raise the vehicle on the ramps, but a low profile jack is probably a better idea. Or try to borrow a lift somewhere.
arabianobsession is offline
Old 10-22-2011, 10:45 AM
mineralpony
mineralpony's Avatar
Lay some wood and drive up on top of it. Make sure its a good couple inches of wood. And then put the ramp in front of it and you should be able to drive onto it.
mineralpony is offline
Old 10-22-2011, 10:50 AM
turbo232
turbo232's Avatar
ifd you have a garage dig an oil change pit like they have at shops. it could also be useful for controlling your mother-in-law.
turbo232 is offline
Old 10-22-2011, 11:00 AM
teej281
4.6L Section Moderator
teej281's Avatar
I run my car up onto some pieces of wood and then put a jack under it and put it on jack stands.
teej281 is offline
Old 10-22-2011, 11:21 AM
945LSTANG
945LSTANG's Avatar
This.
I have a low profile jack and it still doesn't fit under the car without boards under the tires.
945LSTANG is offline
Old 10-22-2011, 12:49 PM
JRad405
JRad405's Avatar
I can always count on your expert opinion lol. I was just curious if that's what most of everyone does or if they bought race ramps.
JRad405 is offline
Old 10-22-2011, 01:32 PM
KillJoy
KillJoy's Avatar
I built my own ramps out of 2x6, they're 5 levels high, and have a slow enough grade that the chin spoiler barely hits the ramp.
KillJoy is offline
Quick Reply: Changing Oil When Lowered
