how wide can i go on my rear tires, ???
Old 11-20-2011, 08:01 PM
Blk003GT
Blk003GT's Avatar
Originally Posted by code3GT
Are you wanting for looks or performance?
Ol boy thinks hes building a 1000hp 2v on the cheap
Blk003GT is offline
Old 11-20-2011, 08:27 PM
code3GT
Mustang Nazi
code3GT's Avatar
He he
code3GT is offline
Old 11-20-2011, 10:20 PM
Digital_Synapse
Digital_Synapse's Avatar
335s fit with the correct rim width and spacing, on a 2" lowered mustang.
Digital_Synapse is offline
Old 11-21-2011, 07:50 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
^ requires the use of a 12" wide wheel (some variation between tire manufacturers) for proper fitment and will need lots and lots of work to get this done (would like to see a "how-to" for an SN95!)
A 335 tire on a 10.5" wheel, has no more contact patch than my 315's on 11" wheels and is a poor fit They may look all fat and bad ***, but lead to a sloppy **** in the corners, poor tire wear and a less than designed safety curve. They will have NO MORE grip than a properly sized tire and even less, most of the time.
croketa1... if you are NOT willing to do maybe more than a little fender rolling and/or massaging, stick with a set of 315's on no less than a 10.5" wheel and will fit fine. This is provided that the off-set is correct (+27mm give/take a small amount) and you don't have un-usually sloppy UCA bushings, or anything funky happening. You "may" need to reverse the quads to gain some clearance, but you can safely remove them completely and best to do so if you have aftermarket LCA's installed anyway.
Jazzer
Jazzer The Cat is offline
Old 11-21-2011, 01:03 PM
croketa1
croketa1's Avatar
Jazzer
coool all that info sounds good man thanks all of you for helping me, i think i might just get som 17 - 11 , on the back for now ill post some piks on my garage whe i get it done thanks guys .
croketa1 is offline
Old 11-21-2011, 04:25 PM
teej281
4.6L Section Moderator
teej281's Avatar
Unless you're getting custom wheels or getting wheels widened, you'll have a hard time finding 17x11 wheels.
teej281 is offline
Old 11-21-2011, 04:32 PM
Aereon
Aereon's Avatar
3.5"?
Hell, even I am not dumped that far. Better check your math, cuz you would be almost literally sitting on the ground!
Jazzer says... huh?
just noticed it heh, I'm about 2.3" lowered and find it somewhat hard to drive, unless you're bagged I dunno how you can go anywhere.
Aereon is offline
Old 11-21-2011, 06:58 PM
KillJoy
KillJoy's Avatar
What's the measurement from level ground to the tops of the wheel wells? I cannot put a finger between my tire and fender in the rear. And i had to cut the front fender well plastic out to clear the front tires.
KillJoy is offline
Old 11-21-2011, 07:03 PM
Aereon
Aereon's Avatar
I measure from the initial height to its current height, I'm currently sitting about an inch and and a qtr off the ground (pipes to ground clearance), I went as far as being half an inch off the ground but couldn't deal with it after a week and readjusted the coilovers to its current height.
Aereon is offline
Old 11-21-2011, 07:17 PM
KillJoy
KillJoy's Avatar
My longtubes are 3/4" from the ground..
KillJoy is offline
Quick Reply: how wide can i go on my rear tires, ???
