Installed HIDs now fogs wont work.
Old 01-02-2012, 10:22 PM
cre03gt
cre03gt's Avatar
Default Installed HIDs now fogs wont work.
I installed HIDs on my 03 GT and now my fog lights wont work with the head lights on and the high beam light stays on all the time. Anyone else had this problem?
cre03gt is offline
Old 01-02-2012, 10:49 PM
Bpohlman13
Bpohlman13's Avatar
Did you get the HIDS with the single beam or dual? Many HIDs dont come with high beams..
Bpohlman13 is offline
Old 01-02-2012, 10:51 PM
Gt04
Gt04's Avatar
I've got the same issue atm, my dad installed them while I was deployed and I haven't gotten around to fixing it yet. Ill try to fix it tomorrow and update if no one else chimes in.
Gt04 is offline
Old 01-03-2012, 07:58 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
What that means is that for what ever reason the high beam power is ON, this activates the fog-lamp cut-off relay blocking them from turning on. You need to determine why the high beam power seems to be permanently on.
cliffyk is offline
Old 01-03-2012, 08:22 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
^ agreed
You have a wiring issue, but cannot figure it out from here
Go over ALL the details of the wiring and keep in mind the following things:
1. When the high-beams go on, the low-beams go off.
2. When the high-beams go on, the fog lights go off.
Go back over ALL of the connections and make sure they make sense. Sounds to me, you have a dual-HID bulb, as my pepe Bpoh has suggested. Are these HID's being installed in the OEM headlights?
Jazzer
Jazzer The Cat is offline
Old 01-03-2012, 10:36 AM
cre03gt
cre03gt's Avatar
They are single beam. Ill look over the wiring again. thanks for the help.
cre03gt is offline
Old 01-03-2012, 03:26 PM
JRad405
JRad405's Avatar
You may have just swapped a wire. I did that to my HID's the first time I put them in. I had 3 wires because I had a hi beam on mine. I just had to switch the two wires that were on opposite sides and it worked fine after that.
JRad405 is offline
Old 01-03-2012, 04:54 PM
cre03gt
cre03gt's Avatar
do you remember which wire it was? were yours bi-xenon bulbs?
cre03gt is offline
Old 01-03-2012, 09:17 PM
JRad405
JRad405's Avatar
Not to sure on the wire and bulb. If DDM tuning bulbs are bi-xenon then yes otherwise, I have no idea. There were 3 wires so it was pretty simple to figure out.
JRad405 is offline
Old 01-03-2012, 09:35 PM
KillJoy
KillJoy's Avatar
When you move the headlight switch to the high beam on position, do the fog and parking lights come on?
KillJoy is offline
Quick Reply: Installed HIDs now fogs wont work.
