Vortech'd 99-04 GT's click here!
Old 01-31-2012, 07:01 AM
  #41
StangKid018
StangKid018's Avatar
Alright sounds good. As for gauges what did you decide to go with in your car kerns? Tomorrow ill be buying my FRPP 42 Injectors and he offered me an autometer phantom gauge but never got back to me yet about what the psi max on it was..
StangKid018 is offline
Old 01-31-2012, 10:41 AM
  #42
Fink
Fink's Avatar
I would go with AFR(wideband), Boost(30vac-30psi) and oil pressure.
Fink is offline
Old 01-31-2012, 02:16 PM
  #43
Kerns
Kerns's Avatar
I am running an AEM wideband which I really like, but I wouldn't go with my boost gauge. Its digital and doesn't show partial boost so only 5, 6, 7, 8, 9, 10 ect. If I had to do it over again I would get a more responsive digital boost gauge or a mechanical one.
Kerns is offline
Old 01-31-2012, 06:41 PM
  #44
97stanger
97stanger's Avatar
I run an AEM wideband, boost/vac, fuel pressure, oil pressure, water temp
97stanger is offline
Old 01-31-2012, 09:17 PM
  #45
justinschmidt1
justinschmidt1's Avatar
I only run one gauge, boost...and even that is kinda useless cause it doesnt tell me **** and its not like I look at it.
I thought about removing it once just cause I thought it would be funny to have no gauges and tell people it was stock.
justinschmidt1 is offline
Old 02-01-2012, 09:58 AM
  #46
StangKid018
Come dyno day would you think an AEM Windband and Boost Gauge would be ok starting out for the tuner and then slap in an Oil pressure one soon after?
Old 02-01-2012, 12:06 PM
  #47
justinschmidt1
my tuner has his own a/f gauge that hooks up to his computer as well as boost...Im pretty sure most tuners do this and wont use your gauges
Old 02-01-2012, 02:41 PM
  #48
MCxQubed
MCxQubed's Avatar
Yeah your tuner should hook your car up and use everything they have. The gauges are pretty much for you. And tbh you don't even need gauges if you didn't want them. But they're there to tell you if something goes wrong
MCxQubed is offline
Old 02-01-2012, 05:38 PM
  #49
justinschmidt1
The a/f is good to have just so you can make sure your not running lean...this is about the only thing I really see that will help you keep your motor together.
But you really dont need gauges at all.....
Old 02-07-2012, 10:16 PM
  #50
Red04
Red04's Avatar
Some good info in here!
Red04 is offline
Quick Reply: Vortech'd 99-04 GT's click here!
