Anyone in here running the FRPP Aluminum driveshaft? I plan on installing one when I install the 4.10 gear as well. Are the aluminum driveshafts weak and will it break on hard launches? I only plan on getting it because I have heard alot of stories of the 4.10 gears cause the OEM driveshaft to "vibrate"
The aluminum shaft is stronger than the OEM shaft due to the beefier u-joints, you would blow a U-joint out way before you would snap a driveshaft in half and with that being said you have better chance of u-join failure on the factory peice.
