Yet another Mark VIII swap thread
Old 04-06-2012, 06:20 AM
  #21
Tesla_HV
Tesla_HV's Avatar
There are a lot of various sensors to unplug. I really should learn their function so that I can determine the differences between the SOHC/DOHC wiring harness connections. More this weekend.
Tesla_HV is offline
Old 04-06-2012, 06:21 AM
  #22
uberstang1
Chupacabra
uberstang1's Avatar
Originally Posted by sn95_331_GT_ yellow
no, not the radiator, the fan/shroud assembly
GT's and Cobra's used the same ones
Actually they didin't the cobra used the same fan as the 3.8s, GTs used a different fan.
uberstang1 is offline
Old 04-06-2012, 06:23 AM
  #23
uberstang1
Chupacabra
uberstang1's Avatar
Originally Posted by Tesla_HV
It looks to go into the head and not the intake but it also looks to get in the way. Here is how it enters the head...
You need to remove the nuts holding them to the intake manifold and they try and pry that crossover tube out, its sealed via o rings but they get seized into the heads. What conidition is that lincoln motor is, by the looks of the contact surfaces on the pullies its been sitting for quite some time, probably exposed in elements.
Old 04-06-2012, 06:28 AM
  #24
Tesla_HV
Tesla_HV's Avatar
It's a relatively low mileage engine (~60k miles) but it has set in a salvage yard for two years. I have a 90 days warranty. That's one of the reasons that I am hurrying to get the intake and valve covers off to inspect the internals for exposure damage. It turns over fine.
Tesla_HV is offline
Old 04-06-2012, 08:04 AM
  #25
jeh4269
jeh4269's Avatar
Yeah getting the crossover tube out is a pita.You are gonna love the 4v.It revs much faster than the old 2v.The extra hp & tq you'll have compared to a non pi motor will def make you smile the first time you drive it.Be sure to have it properly tuned to get the most out of it.Swapping a 4v in my car was probably the best thing I could have done for it.Enjoy it
jeh4269 is offline
Old 04-06-2012, 08:14 AM
  #26
Tesla_HV
Tesla_HV's Avatar
I found this advice on another forum:
After disassembling quite a few DOHC's, I've found this to be the easiest method of removing the crossover tube without damaging it. Use a large flat screwdriver to carefully pry up on one side at a time at the temp sensor bungs, like so...
I'll give this a try. I can just tell that this is going to give me problems.
Tesla_HV is offline
Old 04-06-2012, 08:23 AM
  #27
jeh4269
jeh4269's Avatar
Between the age of the engine and the o rings they can be very hard to remove.We had to pry mine out like they said to.We used a big pry bar but I don't think we pryed on a sensor though.It should come out.Good luck.
jeh4269 is offline
Old 04-06-2012, 05:25 PM
  #28
BraMas
BraMas's Avatar
spray around the crossover with some type of penetrating spray. I agree that thing is going to be a pain to get out by the looks of it. You will want to replace the O rings on the crossover and the one on the back of the head you removed. I always use O rings from a O ring kit I got at Harbor Freight. My car has never leaked
BraMas is offline
Old 04-06-2012, 10:21 PM
  #29
jeh4269
jeh4269's Avatar
Agreed brand new O rings are a must.Trust me you don't want to have to remove it twice.
jeh4269 is offline
Old 04-07-2012, 07:50 AM
  #30
Tesla_HV
Tesla_HV's Avatar
Ok here is a fundametal question; since the DOHC engine has a different coil interface, how do you adapt the GT SOHC wiring harness to it? What do I save from the DOHC wiring.?
Tesla_HV is offline
Quick Reply: Yet another Mark VIII swap thread
