Tachometer INOP?
Old 03-31-2012, 08:53 AM
Moonshine
Moonshine's Avatar
Default Tachometer INOP?
Over the last two or so months, my tach has been reading zero at idle (intermittently) and not reading anything until my engine speed surpasses 2500 or so and will 'jump' to correct speed. Often times I'll find that it is reading considerably lower than my actual engine speed.
I spoke with whitefox about this when it started happening and he said something about a relay near/around my coil packs? I do see a small pigtail off of the main harness that feeds to each coil pack that has a small grey connector attatched to it. I'm not too sure if this is what he was talking about, but one could only assume.
Anyone had any similar issues with their tach? Seems strange to me.
Thanks in advance!
Moonshine is offline
Old 03-31-2012, 10:30 AM
kugzgt
kugzgt's Avatar
i like turtles.
kugzgt is offline
Old 03-31-2012, 11:59 AM
Moonshine
Moonshine's Avatar
Originally Posted by kugzgt
i like turtles.
Tell your wife I said "ohai!".
Old 03-31-2012, 12:01 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
I said what!?
Ill look into it a bit later when I get some time
WhiteFoxGT is offline
Old 03-31-2012, 12:02 PM
kugzgt
kugzgt's Avatar
as soon as i leave ur sisters place. BOOM!
kugzgt is offline
Old 03-31-2012, 12:12 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Happy hunting! My opinion, the cluster is fubar'd
Old 03-31-2012, 01:35 PM
neo8222
neo8222's Avatar
You could always put the cluster in the diagnostic mode and see if the gauges sweep correctly and if the PCM is giving the correct information to the cluster.
http://www.mustangworld.com/ourpics/News/99hec.htm this link will give you the info how to get into diag mode and what all the prompts mean.
neo8222 is offline
Old 03-31-2012, 01:51 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
That only works for 99+ mustangs. With the digital odometers. -98 was analog
Old 03-31-2012, 03:17 PM
Moonshine
Moonshine's Avatar
Weak sauce. Where does the PCM get rpm info FROM?
Old 03-31-2012, 04:25 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
crank sensor. thats not your issue. If the rpm source was the issue, the car would not run. Its running fine, leading me to believe its a com/part error on the gauge side. I bet the motor in the cluster is on its way out
Quick Reply: Tachometer INOP?
