Motor swap almost complete
Maybe the stock t45 will finally throw in the towel, but that damn transmission has been hella good to me, and has been beat worse that whitney houston after bobby brown coming home from the bar.
I meant to text you, that aluminum drag pan simply cannot be put on wih the motor out of the car as it wouldnt drop in with the k frame installed, so for the time being im not running it. To get that pan on u have to jack the motor up enough to remove the pickup tube and remove and install pan from the rear of the k frame. Which im not messin with atm because im time constraints. That pan isnt usable with a stock k frame ether no way. I did soem reasearch and thats not the standard 7qt moroso pan which essentialy is a stock pan with a kickout welded on it but rather its their double kick out all alumunim drag pan. I plan on getting it on somepoint after the carlisle show.
Lube I gotta admIt you're pretty fukkkin funny in this thread.
"spin it to the moon, we'll have to find out soon" you're like Edgar Allen Poe with a big *** head and race gas in your veins.
You're the man Lube
You're the man Lube
