Forged 28 spline axles?
Old 05-04-2012, 09:29 AM
HamMach1
HamMach1's Avatar
Default Forged 28 spline axles?
Since our axles suck, would beefed up 28 spline work well? Or is 31 diff and axle the only way to go
HamMach1 is offline
Old 05-04-2012, 10:05 AM
Armystrongmach1
Armystrongmach1's Avatar
Depends on the amount of HP/TQ you are throwing at the axles and the type of tire you plan on using.
Armystrongmach1 is offline
Old 05-04-2012, 10:08 AM
Moonshine
Moonshine's Avatar
No...depends on how much money you want to spend. You could probably find an SRA from a Cobra and bolt it in.
That would probably be your cheapest option. Plus you get the 11" brakes.
Moonshine is offline
Old 05-04-2012, 10:11 AM
Armystrongmach1
Old 05-04-2012, 12:31 PM
HamMach1
HamMach1's Avatar
Well I have no plans for power adders any time soon so ill probably linger around 300rwhp and I'd like to be able to run a slick
HamMach1 is offline
Old 05-04-2012, 01:49 PM
Moonshine
Moonshine's Avatar
I'd look for the cobra rear. It will do everything you ask of it.
Old 05-04-2012, 02:01 PM
teej281
4.6L Section Moderator
teej281's Avatar
Ok, if you're talking about new edge cobras, they all came with an IRS, and the early ones sucked. However they tend to take slick launches better than dr's. If you're talking about SN95 cobra rears, they do not have 31 spline axles or diff. They are 28 spline just like the GT's. They are no better.
OP, I'd say that you'd be fine upgrading just to forged 28 spline axles. I haven't seen any data about forged 28 vs. forged 31 ever. But chances are with only 3 more splines, there will be a difference, but how much I have no idea.
teej281 is offline
Old 05-04-2012, 02:43 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
The stock 28-spline axles are "forged", that's the way anything expected to do that sort of job would be made. Also I would disagree that they suck as they can actually handle quite a bit more torque than the stock engine puts out.
Here are the torque ratings for the Ford 28 and 31-spline axles (from tests performed for Fourwheeler magazine):
COT: Continuous output torque rating
MOT: Maximum output torque rating
Ford 8.8 28-spline COT: 1250 lb-ft MOT: 4600 lb-ft
Ford 8.8 31-spline COT: 1360 lb-ft MOT: 5100 lb-ft
You can see that the 31-spline axle has just an 8.8% higher continuous rating, and a 10.8% higher maximum rating--so it really isn't THAT much stronger.
The aftermarket axle makers claim the splines on their 28-spline axles are stronger then on the stock axles, one maker claims 35% stronger.
That said it is foolish to ever believe anything anyone trying to sell you something says.
Getting back to the stock 28-spline axles, if we assume 4.10:1 gears then 4600 lb-ft out would be 4600/4.10 = 1122 lb-ft in to the rear end. Now if we assume 2nd gear (2.0:1) with perfect traction that's 1122/2.0 = 561 lb-ft into the tranny. If we further stipulate that the engine's peak torque happens around 5252 rpm then that would be 561 fwHP, or 476 rwHP with a 15% powertrain loss.
Now that would be pushing the axles right up to their limit, so if we include a 0.8 design buffer that becomes 476 * 0.8 = 382 rwHP--or just about what most people here would consider to be the limit for the stock 28-spline axles.
cliffyk is offline
Old 05-04-2012, 08:07 PM
CobraFrenzy
CobraFrenzy's Avatar
Haha wut? ^^^^ good lawd
CobraFrenzy is offline
Old 05-04-2012, 08:08 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
It's called engineering...
cliffyk is offline
Quick Reply: Forged 28 spline axles?
