Need some help with suspension setup
Old 02-28-2013, 07:59 PM
fastsilverstang
fastsilverstang's Avatar
Exclamation Need some help with suspension setup
Hi Everyone!
I have a 2000 Mustang GT Convertible that needs new ball joints and tie rods so I was thinking to put lowering springs on too. My Mustang is all stock besides the 18x9 Saleen wheels. I really want to start to convert it to a Saleen clone because I can't find any in my area.
What do you guys suggest on what I should get for my suspension?
SHOPPING CART
Items:
H&R Super Sport Springs - Convertible (94-04 All; Excluding 99-04 Cobra)
SR Performance Polyurethane Spring Isolators - Front (79-04 All)
SR Performance Polyurethane Spring Isolators - Rear (79-04 GT, V6, Mach 1; 93-98 Cobra)
Maximum Motorsports Caster Camber Plates (94-04 GT, V6, Mach 1; 94-01 Cobra)
2 - Tokico HP Series Front Strut (94-04 All)
2 - Tokico HP Series Rear Shock (94-04 GT, V6, Mach 1; 94-98 Cobra)
Steeda Bumpsteer Kit (94-04 All)
Steeda X2 Ball Joint Kit (94-04 All)
Thanks for the help!!
fastsilverstang is offline
Old 03-01-2013, 01:10 PM
califas_1987
califas_1987's Avatar
Seems like your replacing alot up front. Why not go for coil overs? It will give you better performance and improve the geometry of our outdated fox body design.
califas_1987 is offline
Old 03-01-2013, 05:44 PM
AMWill
Former Sponsor
AMWill's Avatar
OP,
Looks like a very solid setup to me. Were you planning on adding a rear suspension components, like LCA's, UCA's, sway bar, etc. I'm assuming this is suppose to be a road course car?
Shane
AMWill is offline
Old 03-01-2013, 06:57 PM
Seabee1993
Seabee1993's Avatar
Sound good!
Seabee1993 is offline
Old 03-01-2013, 08:52 PM
fastsilverstang
Hi califas_1987, I just don't know if I really need to get all of it. I'm trying to look around online for some help to lower the 4x4 Mustang right. I thought about coil overs but I don't really think I need them. Its just a daily driver to have some fun with but thanks for the suggestion!
Old 03-01-2013, 09:02 PM
fastsilverstang
Originally Posted by AMShaneLesky
OP,
Looks like a very solid setup to me. Where you planning on adding a rear suspension components, like LCA's, UCA's, sway bar, etc. I'm assuming this is suppose to be a road course car?
Shane
Hi Shane, Not sure on the rear suspension. I really just want to lower it but not sure what is the right way to do it. Lowering springs, shocks, caster camber plates, etc? Its not going to be a road course car, just a daily driver but that would be fun. Can you PM a code for AM?
Old 03-04-2013, 02:18 PM
AMWill
Former Sponsor
AMWill's Avatar
I would start with Springs, CC plates, Struts, and Shocks at the minimum. Then you can always add a good bit from there, depending on what suites you the best.
Also, I got your PM about the discount code, but you currently have you PM's disabled. So, I'm not able to reply, at the moment..
Go into your User CP settings and enable your PM's, then shoot me another message to let me know you fixed it!
Shane
AMWill is offline
Old 03-04-2013, 03:03 PM
uberstang1
Chupacabra
uberstang1's Avatar
For what your doing it sounds alright, I look at UPR for caster camber plates/bumpsteer.
uberstang1 is offline
Old 03-04-2013, 05:34 PM
school boy
school boy's Avatar
drop the steeda x2 ball joints. I have seen these come apart. just buy oem ball joints.
school boy is offline
Old 03-04-2013, 07:26 PM
luke1333
luke1333's Avatar
Hi Everyone!
SHOPPING CART
Items:
H&R will sit low for a daily driven car and not sure the tokico will be able to keep with with the H&R for a long time. Get the bilsteins if you can afford them. I would reuse stock isos if you can save money and those isos add to the ride height not make lower. but other then that looks good!
luke1333 is offline
Quick Reply: Need some help with suspension setup
