Did I blow it?
Old 05-19-2013, 08:57 PM
silvr002001
silvr002001's Avatar
Default Did I blow it?
So I recently installed a zex wet system. I am running the 100 jets. I also have installed a window switch that is set to activate at 3100 rpm. However I jacked up the window switch wiring and I sprayed at like 2500. Nothing catastrophic happened during the spray. After I sprayed one more time after fixing the wiring. This time it activated at the proper 3100 rpm.
As soon as the has hit I broke traction so bad I had to get out of the gas. I was testing to see if I had the switch properly wired and now I did. However after, the car seemed bogged down. I drove to a stop light where it just stalled and died. After about an hour or so I got it back started and drove it home missing.
Once I got home I have the trouble code coil on plug for #1 cylinder. I replaced the coil and started it. It seemed to be fine. I drove it a bit and it drove fine a while then started missing again. I came home checked the coil and it was not really firing from what I could tell. I removed it while the car was running. No spark. So I took the coil from cylinder 5 and put it on there. No spark. So I took the coil from cylinder 6 and put it on 5. It worked. Then I took the coil and put it on 1 and it worked. Bought another new coil. All coils are now firing. I haven't drove it again yet. It idles fine but then when you push the clutch in, the idle drops a good bit to where it doesn't sound right.
When you release the clutch it goes back to normal. This is driving me nuts. I don't know if anyone has any insight but all is appreciated. Sorry for the long read
silvr002001 is offline
Old 05-19-2013, 09:11 PM
silvr002001
Forgot to add that I replaced plugs already to no avail
Old 05-19-2013, 10:02 PM
uberstang1
Chupacabra
uberstang1's Avatar
Did u have the car tuned with the nitrous?
uberstang1 is offline
Old 05-19-2013, 10:26 PM
silvr002001
Yes I was running a bama tune for 100 shot of nitrous. Also the coil on plug cylinder 1 code just came back. I took the coil out with it running and it was sparking. So the coil appears to be good
Old 05-20-2013, 06:56 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Check compression on cyl1
WhiteFoxGT is offline
Old 05-20-2013, 12:56 PM
uberstang1
Chupacabra
uberstang1's Avatar
Bama tune? As in mail order tune?
Old 05-20-2013, 12:57 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
What was the DTC you observed?
cliffyk is offline
Old 05-20-2013, 02:08 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Mail order tune for Nitrous of FI is not good. Eventhough the company you mentioned is great at doing tunes when you get into boosters (FI or Nitrous) it's really best to get on a dyno for a full custom tune because any small variables in your A/F that the mail order tune won't pick up on is magnified by like 10 times.
Anyways, any smoke coming out the tailpipe? How'd the plug look on cyl 1?
What codes are stored in PCM?
Derf00 is offline
Old 05-20-2013, 03:16 PM
silvr002001
yeah it was a bama mail order tune. the only DTC that im getting is the"p0301 coil on plug" code. I can clear it and it still comes back. even when it does come on, i have pull the coil with the car running and it the car will stumble and i can observe steady spark. The car seems to idle fine. When you push the clutch in the car will drop idle to by at least 100. Down to where it never idled before all of this. The plug on cylinder 1 looked ok. Actually they all did. There is some light white smoke coming from the tail pipes now. it isnt a thick cloud or anything. It is however another thing that was not happening prior to this. That along with the sweet smelling puddles of water that now accumulate under the tail pipe, i'm fearing the worst. I will drain the oil and see if it looks milky.
Old 05-20-2013, 04:52 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
P0301 is not a "coil on plug" code (that would be one of P0351 through P0358), it is a misfire detection code for cylinder 1--read more about the possible causes here.
Misfire codes can be thrown for any reason that causes a misfire (lack of a combustible fuel mix, compression, or spark), not just ignition problems. As suggested by others you need to do a compression test to first make sure there is not a mechanical problem, then move on to fueling and ignition.
cliffyk is offline
Quick Reply: Did I blow it?
