Tune Up? Almost 130k
Old 02-01-2014, 10:17 PM
Formless
Formless's Avatar
Exclamation Tune Up? Almost 130k
Just wondering what your guy's opinions would be on what to tune up the car at this many miles? I need to changes the spark plugs for sure and clean my air filter. The car has been feeling just a bit sluggish recently. Here's what I've done recently:
Motor Oil and Filter are OK
Tranny Fluid is OK
Struts and Shocks are OK
Formless is offline
Old 02-02-2014, 12:02 AM
SyNdicateZ
SyNdicateZ's Avatar
Fuel filter
Coolant change
Pcv valve......?
SyNdicateZ is offline
Old 02-02-2014, 01:09 AM
H0SS302
H0SS302's Avatar
Brake fluid, diff fluid, coolant flush, clean your maf, check PCV/IAC valves/ check ball joints, grease your suspension/hinges, fuel filter, power steering flush....you name it, at 130k it needs to be flushed or replaced if you want the car to last.
H0SS302 is offline
Old 02-02-2014, 12:07 PM
Formless
Formless's Avatar
Oh yeah, forgot to mention the fuel filter was changed less than 6k miles ago. How complicated is it to check the PCV/IAC valves?
Formless is offline
Old 02-14-2014, 01:57 PM
302_Mustang
302_Mustang's Avatar
Very easy, changing both should take 20 mins at most with basic tools
302_Mustang is offline
Sixx
10-05-2015 07:36 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
Explosive
10-02-2015 07:45 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Quick Reply: Tune Up? Almost 130k
