spit and sputter
Old 09-03-2014, 05:27 PM
thrasher246810
thrasher246810's Avatar
Default spit and sputter
I have an 04 mustang gt. With bbk lontubes bbk uncatted xpipe SLP loud. Mouth mufflers my check engine light Is on Amd flashes which means multiple misfire. Would mil eliminaters and tune fix this? Please help
thrasher246810 is offline
Old 09-03-2014, 05:28 PM
thrasher246810
also runs like crap spits and sputters
Old 09-03-2014, 05:29 PM
dawson1112
dawson1112's Avatar
Uh no , if your engine light is flashing it is due to something serious. Take it and have the codes read, would be my first course of action.
dawson1112 is offline
Old 09-03-2014, 05:30 PM
dawson1112
dawson1112's Avatar
A simple illuminated check engine light is just a reminder that something is wrong.
A constant flashing light means it is imperative you get it checked.
Old 09-03-2014, 05:38 PM
thrasher246810
Its been parked since it started doing it. I looked up what the flashing meant it said multiple misfire. Someone told me it was due to lack of o2 sensors. Guess I'll et her checked out
Old 09-03-2014, 06:07 PM
dawson1112
dawson1112's Avatar
No sir lack of 02s would just set off a check engine light it wouldn't flash. And you need front 02 sensors those are the upstream sensors that tell the computer what your air/fuel is. The rear 02s are the down stream sensors and are only there to compare data from the front two so it knows how efficient the cats are. You can have the rear 02s turned off with a tune and not have any ill effects , the upstream sensors have got to be there or the car goes into limp home mode... and the computer defaults to a rich mixture for engine safety purposes.
Old 09-03-2014, 08:05 PM
VTX1800N1
VTX1800N1's Avatar
Flashing just means it's misfiring. It could be just one cylinder or many. You need the codes read to find out.
Sent from my XT1080 using IB AutoGroup
VTX1800N1 is offline
ShaneB26154
35
03-04-2021 04:05 AM
MEISTERSNFB
03-31-2020 07:50 AM
JaxJags88GT
03-11-2005 10:43 PM
97STANG
07-02-2004 07:18 PM
Quick Reply: spit and sputter
