White smoke gone, now grey smoke.
Old 08-20-2015, 01:42 PM
overnight89
overnight89's Avatar
Post White smoke gone, now grey smoke.
Hello All,
I have recently started my account here, but have come to the forums in the past. My issue with my 99 ford mustang GT, is that I am getting grey smoke coming mainly from my left exhaust, and a little from the right. Originally it was white smoke, but I later found out the coolant going into my firewall for my inside heat was cracked at the firewall and was leaking alot of fluid into the spark plug holes. It didnt get past the spark plug, but was stuck in the hole above the spark plug. After blowing and removing the coolant, I am now seeing grey smoke from the exhaust, and cannot figure out what the problem is. I will post a video today when I get off of work, if anyone has a clue.
overnight89 is offline
Old 08-20-2015, 09:14 PM
overnight89
Video of Smoke
Old 08-21-2015, 06:32 PM
Camster
Camster's Avatar
Is the antifreeze level dropping? I'd pressure test the system.I suspect a problem with the left head or head gasket.
Camster is offline
Old 08-21-2015, 08:55 PM
jwog666
jwog666's Avatar
yeah im gonna guess by the quantity of the smoke that you are burning coolant, head gaskets are the most likely cause
jwog666 is offline
Old 08-22-2015, 10:08 AM
overnight89
Yea I had a feeling just needed a second opinion. I am gonna take it apart this weekend and check on them, as well as doing a coolant pressure test. I will update later today if I finish.
-thanks yall
Old 08-22-2015, 11:14 AM
Camster
Camster's Avatar
-thanks yall
You might do a compression test as well,if only to get a better idea of what may be going on in the right head..
If I was in your shoes,I'd pull both heads,have them checked for warpage,replace both head gaskets,and change the oil.It may be contaminated.
Camster is offline
Old 08-22-2015, 09:02 PM
overnight89
Pic after pulling manifold. Smh.
b8checker
10-08-2015 12:55 PM
breaking
10-02-2015 01:27 PM
14gt_Track
10-01-2015 02:47 PM
RCS02v6
09-29-2015 01:46 PM
MacSerio
09-27-2015 01:05 PM
Quick Reply: White smoke gone, now grey smoke.
