275 tires in front
Old 08-21-2015, 03:54 PM
zachary1988
zachary1988's Avatar
Default 275 tires in front
I would like to put 275x35x18 in the front. I have an 04 GT with Eibach Sportline lowing springs. I have 245x40x18 right now and 275x35x18 in rear by Continental. I don't like the stance and will put 295 in rear. Will the fronts rub when turning? Thanks, Ed.
zachary1988 is offline
Old 08-21-2015, 07:25 PM
Gt04
Gt04's Avatar
I run 275 fronts I'm sitting pretty low, I don't rub at all
Gt04 is offline
Old 08-21-2015, 07:35 PM
zachary1988
Thanks for your input, Ed.
Old 08-21-2015, 08:26 PM
99GTvert
is my username.
99GTvert's Avatar
I have stock springs and the 275s only rub when the steering wheel is at a left or right lock (all the way).
99GTvert is offline
Old 08-21-2015, 11:01 PM
school boy
school boy's Avatar
The big question in that setup will be if you are running the correct wheel backspace. If so, then no problems. What wheels are you running?
school boy is offline
Old 08-22-2015, 07:30 AM
zachary1988
I have the American Racing Torq Thrust in the Anthracite, 18x9 in front and 18x10 in the rear. Thanks, Ed
Old 08-22-2015, 11:07 AM
school boy
school boy's Avatar
Being built to fit a 94-04 mustang, the backspace will be correct.
Old 08-22-2015, 07:58 PM
zachary1988
I appreciate your help. Thanks, Ed.
Old 08-31-2015, 01:30 PM
LilRoush
LilRoush's Avatar
On 18x9/10 - run a 265/35 and 295/35 set up.
LilRoush is offline
Old 08-31-2015, 01:52 PM
Granatelli Sales
Former Sponsor
Granatelli Sales's Avatar
Yes, the 275/35/18 will fit up front as long as you have the correct width wheel and the right backspacing/offset. I believe the 2003-2004 Cobra wheels were 17"x9" with a +24mm offset and ran a 275/40/17 tire.
Many people run a 315/30/18 or 315/35/17 in the rear, and I have hear of people stuffing a 325 or 335 width rear tire with some modifications. You should be running a minimum of a 10" wide wheel for a 295, and at least a 10.5" wide wheel if you want to go larger.
Granatelli Sales is offline
Quick Reply: 275 tires in front
