Missfire or trans
Old 05-20-2016, 05:35 PM
Dekevius1
Dekevius1's Avatar
Default Missfire or trans
OK I have a 2000 mustan gt stock aftermarket filter is the only change.190k miles on it with only one code pop up it say its the trans sensor or batter connection.battery good no missfire only thing is when I cruise around 50 and 70 mph it has a slight missfire to me and I can also hear from exhaust a backfire tape of sound can someone pleas help I changed sparkplugs,fuel filter, aac, cleaned throttle body and still no change in skip and no other code pop up.
Dekevius1 is offline
Old 05-20-2016, 06:44 PM
school boy
school boy's Avatar
Whoa there buttercup, try using punctuation. May try checking and cleaning all electrical connections and grounds. Also use fuel injection cleaner. At 190,000 miles, I bet it wouldnt hurt.
school boy is offline
Old 05-21-2016, 10:11 AM
dawson1112
dawson1112's Avatar
If the COPs have 190k on them I recommend you inspect them all for cracks on the tops of them. My 2000 has 241k on it and I just recently replaced all of mine because they were the original ones and every one had a crack across the top of it. That lets them draw moisture into the windings and they will have a slight miss fire to them.
dawson1112 is offline
Old 05-21-2016, 12:03 PM
Z28KLR
Z28KLR's Avatar
Also check the rubber boots on the COP's. Any cracking or deterioration or signs of current arcing through (often looks like a brown-ish dust substance if it's been going on for a little while) then you can just replace whatever boots as necessary. They go for about $10 each at your local parts store.
Also, please post the actual DTC (code) that you're getting. Knowing that will go a long way in helping us help you.
Z28KLR is offline
LostOblivion
04-11-2016 01:27 PM
GStam66
04-09-2016 01:50 PM
Mach2
03-28-2016 11:29 PM
Galicia Fabian
03-24-2016 01:02 PM
UltraBlue91'
03-07-2016 07:01 AM
Quick Reply: Missfire or trans
