Oil type and changing intervals
Old 01-17-2017, 08:13 AM
Riverrat 1948
Riverrat 1948's Avatar
Default Oil type and changing intervals
I own a 2002 GT Vert and drive it only about 4K-5K miles per year. It is strictly my weekend car and only when the weather permits for the top to be down. What is ones recommendation on type of oil and changing intervals for this type of use?
Riverrat 1948 is offline
Old 01-17-2017, 12:32 PM
movielover40
movielover40's Avatar
I would use Mobil One synthetic and change it once a year tops.
movielover40 is offline
Old 01-17-2017, 01:55 PM
Camster
Camster's Avatar
My 04 gets about the same type of use.
I think once a year is fine,though I've mostly done it about every eight months with syn blend.
Camster is offline
Old 01-18-2017, 01:06 PM
Riverrat 1948
Thanks for the recommendations.
Old 01-18-2017, 01:36 PM
99GTvert
is my username.
99GTvert's Avatar
I would do twice a year with synthetic blend. Full synthetic is not a bad alternative though once a year.
99GTvert is offline
Old 01-24-2017, 05:17 PM
lizzyfan
Underboss
lizzyfan's Avatar
Torco SR-1.....once a year
lizzyfan is offline
Old 02-05-2017, 08:47 AM
Riverrat 1948
Default Manual Transmission Service
How often should the manual transmission and rear differential oil be changed?
Old 02-05-2017, 02:25 PM
Camster
Camster's Avatar
I think at 50K for the trans and 75k for the diff.
Camster is offline
Old 03-10-2017, 04:22 PM
95 MERC
95 MERC's Avatar
Default Differential Lube Change Interval
Standard lube capacity for the FOMOCO 8.8 Differential is 60 Ounces.
Using the Ford Racing Differential Girdle, the lube capacity is 80 Ounces.
For bullet-proof performance, get a re-useable LUBELOCKER differential gasket. No RTV sealant is necessary with the LUBELOCKER
I use and recommend Royal Purple 75W-90, because there's no need to add Friction Modifiers for a limited-slip differential. The Friction Modifiers are "built in" to the Royal Purple Synthetic Gear Lube.
When using the Royal Purple synthetic lube, follow these recommendations:
For high-performance street use, change the lube at 50,000 miles.
For racing, change the lube at the beginning of each racing season.
95 MERC is offline
