Oil Separator - Attn: MODADDICT
Post revised, with modaddicts recommendation
and ordering info:
This setup is for -10AN.
"if you want the ***** best, here's the recipe... "
#5122 Stef's -10AN air/oil separator 98.00
Order on-line or call 800.418.9573
Summit Racing:
MOR-63401 3" can bracket 6.95
SPE-3260 5/8" clamps (qty-2) 13.90
EAR-403010ERL 3ft -10 Perform-O-Flex hose 32.39
EAR-812010ERL -10 120* swivel-seal hose end 25.95
EAR-800110ERL -10 straight swivel-seal hose end 10.95
And here are MODADDICTS thoughts, on why we need an
air/oil separator, incase you don't want to have to
read the whole thread.
Here is S197 PCV 101:
Follow this closed loop PCV system in your mind. Our cars draw air IN to the
passenger side cam cover. This air comes from the intake tube AFTER it has
passed through the MAF sensor so it has been cleaned by the air filter and
metered by the MAF meter. This air circulates through the motor and is sucked
OUT of the drivers side cam cover and into the the intake manifold BEHIND the
throttle body. This suction draws oil vapor with it from the crankcase and this oil
will contaminate the Air/Fuel mixture, create burnt oil deposits on your pistons and
valves, and put a nasty coating on your supercharger intercooler if you have one.
Not to mention shortening the life of your $90.00 spark plugs and gunking up your
throttle body not to mention other more sinister long term possibilities.
So, you put an Air/Oil separator in the line that runs from the Drivers side cam cover
to the intake manifold.
Spend the money and do it correctly! Don't skimp and get the thimble sized glass
one (like the junk steeda one posted in the thread) because it will fill too quickly
and become a maintenance issue. Don't try to save money and get a "catch can"
(like the SHM 2V one ham asked about in this thread) because it is cheaper. It will
require modification to work properly. Get a good Air/Oil separator and plumb it properly.
Now you don't have to use this parts list and some complete kits like the stefs are good
units. But if you want the ***** best, here's the recipe...
and ordering info:
Summit Racing:
RE: Oil Separator - Attn: MODADDICT
That's for a 2V...
Trust me, a catch can with good SS lines and good fittings is the the way to go on our cars. Don't skimp on the lines and fittings, that's the most important!
Even if you're not seeing a lot in your TB, believe me, if you broke down your blower - you'd find tons under the manifold. Everyone FI should have a good catch can set-up IMO. It's relatively cheap and easy and just plain smart.
thanks m, i will take your input under
advisement
seriously tho, not the answer i was hoping for....
i guess i'll go back to the drawing board tomorrow.
advisement
ORIGINAL: howarmat
Would you recommend the stefs?
Whatever you do don't pay $44 for the summit racing -12 AN blue twist tight hose, it will collapse under vacuum.[:'(]
I've seen it (oil)in the heads too.. A modded KB with 10,000 miles looked terrible manifold down. You can't see it happening but it's there...
ORIGINAL: modaddict
That's for a 2V...
That's for a 2V...
