Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-11-2008, 02:53 PM   #61
Derf00
Fuel way below the "rated" octane...what octane is the tune made to run on?
Derf00 is offline   Reply With Quote
Old 11-11-2008, 08:04 PM   #62
five pt oh
Quote:
set for 87, running 87. I even filled up once between the two times it happened. So it happened with 2 different tanks on gas from 2 different places.
So my gut reaction was that it was a spark issue, not a fuel issue.
Then again, I wonder if maybe it's a fuel filter issue, but in the time I spent unloading & reloading tunes, the fuel pump forced enough through the fuel filter to get it started. If so, then it wasn't a flash tune issue after all.
__________________
five pt oh is offline   Reply With Quote
Old 11-20-2008, 02:05 AM   #63
Z06 Killer
Vehicle: '06 Mustang GT
Send a message via Yahoo to Z06 Killer
For those who like to tune like a pro try the Sniper software.
__________________
When in doubt..... Throttle it out!
PAXTON CREW MEMBER!
Z06 Killer is offline   Reply With Quote
Old 12-06-2008, 10:36 PM   #64
Grabber8608
Vehicle: 2008 ford mustang gt
Default Need help with my tuner
Alright I just got a SCT tuner the other day and loaded it up with no problem. Then I went for a quick spin around the block. Turns out that my speedometer is high by about 10MPH at 40MPH. I went back to the shop that i got it from and we uninstalled and restalled the program and it is still off. I have 4:10 gears, short-throw shifter, ford cold air intake and everything else is stock. If anyone else has had this problem and managed to slove it please let me know what i have to do.
Grabber8608 is offline   Reply With Quote
Old 12-15-2008, 10:41 AM   #65
Jesse@SCT
Jesse@SCT's Avatar
Vehicle: Ford
What type of tuner are you using? The 4:10 gears are whats going to be throwing your speedo off. Depending on your tuner you will have adjustable options to change these gears to correct you speedo.
Jesse@SCT is offline   Reply With Quote
Old 12-16-2008, 10:13 AM   #66
stang5151
stang5151's Avatar
Vehicle: 2005 Mustang GT Premium - Redfire
I had the same issue after installing the 4.10's. Just as Jesse says - the tuner can fix it with the adjustable options. I have the XCal 3 - love it. Easy to use, easy to upload tunes to, etc.
stang5151 is offline   Reply With Quote
Old 12-25-2008, 09:00 AM   #67
GT John
Quote:
Its always nice to see the folks from SCT jump in. Thanks Jesse.
__________________
2005 Mustang GT - Automatic
WMS 80mm HV Intake System
SCTuning by John and Matt - Mustang Muscle Performance
WMS 80mm 93 Octane Race / Tran Tune
BMR Front Sway Delete, IMCO Extreme Axle Back Exhaust, Saleen SS UDP's, PH Aluminum DS, Steeda LCA's, Steeda UCA, FRPP 3.73
GT John is offline   Reply With Quote
Old 12-25-2008, 09:32 AM   #68
sugarandopium
sugarandopium's Avatar
Vehicle: 08 GT/CS - 87 GN
Can you manually turn off the "adaptive throttle response" with a predator?
sugarandopium is offline   Reply With Quote
Old 12-25-2008, 12:17 PM   #69
05gt128
2005 Ford Mustang
Vehicle: 2005 ford mustang gt
i have a predator programer and think its great, but ive noticed that diablosport.com has updates for it in the download section of there web site,my question is should i be updating it or is it nothing to important
05gt128 is offline   Reply With Quote
Old 12-25-2008, 08:57 PM   #70
CavScout2e
Vehicle: 2008 Ford Mustang GT
Default SCT X3 tunner
I just bought and installed the Steeda cold air kit (witch looks exactly like my brothers ford racing kit) and after loading the tune the check engine light came on after about 10 mins of driving. I disconected the batt and that got rid of the o2 sensor dtc's, I then uninstalled the tune and reloaded it. The light went away but now the dtc says that B1 and B2 banks 1 and 2 are running lean. How can I fix this?
Running this on a 08 GT, only other mods are flowmaster axle back system.
CavScout2e is offline   Reply With Quote
2006, 2008, cai, custom, data, generic, give, gt, horsepower, loading, mustang, pcm, sct, settings, tune, tuner, v8
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
