331 vs. 373 gears
Old 01-02-2008, 10:39 AM
ssemich
ssemich's Avatar
Default 331 vs. 373 gears
Hello,
I have a 2007 Ford Mustang GT,5 speed manual. It has Superchips flashpaq, JLT CAI, CDC Skaker,CDC Chin Spoiler, CDC Foose Hood.
I am considering 373 gears and would like to know what the advantages and disavantages are? I heard you lose some of your top end?
My current gears are 331...I primarily drive highway. Car is a daily driver...
Thanks,
Steve
ssemich is offline
Old 01-02-2008, 10:45 AM
pnicholson
pnicholson's Avatar
Default RE: 331 vs. 373 gears
Hey there,
Go with the 3.73's. You will loose a little top end - but since you dont drive up there anyway (NOBODY does) its not a huge deal. You will loose a couple hundred RPM at freeway speeds, but will gain a noticble boost in pull from the bottom end.
Page
pnicholson is offline
Old 01-02-2008, 10:49 AM
acascianelli
acascianelli's Avatar
Because our cars are drag limited, you might actually gain some top end speed.
acascianelli is offline
Old 01-02-2008, 10:54 AM
ssemich
ssemich's Avatar
Okay...Thanks....Another question...So going from 60-80 mph in 4th or 5th gear on the highway for passing will be quicker or slower?
Steve
ssemich is offline
Old 01-02-2008, 10:58 AM
onederful100
onederful100's Avatar
get the 3.73's or even 4.10's are ok for daily driver. with my 4.10's when cruising, its not that noticable, but when you get on it the accelleration is much better. the pro's devinately out way the cons. you may lose 1 or 2 mpg's but who cares.
onederful100 is offline
acascianelli
Quicker. You'd be revving higher, so you'd be closer to your powerband.
Old 01-02-2008, 11:30 AM
ssemich
ssemich's Avatar
okay....great...Thanks for everyones help...
Steve
ssemich is offline
Old 01-02-2008, 01:35 PM
Bluestar
Bluestar's Avatar
I have the 3.73's with a 5 speed as well, you will feel a BIG difference at Hwy speeds as compared to the 3.31's.
Bluestar is offline
Old 01-02-2008, 01:51 PM
ssemich
ssemich's Avatar
cool....looking forward to the kick in the pants feel....
Steve
ssemich is offline
Old 01-02-2008, 01:56 PM
Simon1
Simon1's Avatar
Consider getting a new differential also. They are about 400-450$ and a great mod for future building. There won't be any extra labor since they have toremove the diff from the car anyway. Less $$ when you have to rebuild it later IF you have plans to make more power or going to the track. I'm in the process of buying parts for a new rear end build and will be replacing the diff at the same time.
The 3.73's will be great.
Simon1 is offline
Quick Reply: 331 vs. 373 gears
