Gear Oil Change?
Old 10-17-2008, 10:11 PM
gman73
gman73's Avatar
Default Gear Oil Change?
I had 4.10s installed about 4-5 months ago. Do I need to have the gear oil changed?
gman73 is offline
Old 10-18-2008, 11:07 AM
Argonaut
Argonaut's Avatar
Do you NEED to? No. But it can't hurt, the fill plug is magnetic and you will find bits of metal on it and in the bottom of the pumpkin. This happens during break in, so getting them out of there is not a bad idea.
Argonaut is offline
Old 10-18-2008, 11:23 AM
157dB
Cut & Paste Expert
157dB's Avatar
If the replaced the gear oil with the recommended
Ford Synthetic gear oil, then no, you dont need to change it.
It could be inspected for the proper level, though.
157dB is offline
Old 10-18-2008, 04:54 PM
gman73
gman73's Avatar
My installer used Lakewood's BFL gear oil. I don't have any problems with the gears. For 4.10s they are quiet. No whining at all.
gman73 is offline
Old 10-18-2008, 05:59 PM
SCCAGT
SCCAGT's Avatar
To me, this is a no brainer. There is no filter back there, just a magnet. It wont hold everything. The gears break in, and metal particles circulate. Yes, its a good idea to change out the fluid. I realize so many people have went through cars and never changed the rear diff. The bearings will go bad long before the gears do (providing they were correctly installed). So changing the fluid at least ONCE early on, is just plain good preventative maintenance. Its a whole lot cheaper than going in and doing bearings later on down the road.
3000-5000mi is a good time frame for changing the rear axle oil.
SCCAGT is offline
Old 10-20-2008, 03:11 PM
ajaibr
ajaibr's Avatar
Or you can look at it that Ford doesn't say you need to go change the rear fluid after 5k miles and they deliver the car with new gears also....
If there are enough metal particles collecting in your oil you've got bigger problems than just changing the oil....
ajaibr is offline
Old 10-20-2008, 04:02 PM
Texotic
Texotic's Avatar
it never hurts to change your fluids... but you should be fine.
Texotic is offline
Old 10-20-2008, 04:46 PM
157dB
Cut & Paste Expert
157dB's Avatar
If you have metal particals big enough to cause
bearing damage, you have bigger problems that a
fluid change wont help or wouldnt have helped prevent.
157dB is offline
Old 10-20-2008, 06:06 PM
SCCAGT
SCCAGT's Avatar
My intention of bringing up bearings, was meant for the long term effects of not changing the gear oil. I see it frequently at my shop. Over time, bearings get pitted and start to rumble. Its nothing more than a good preventative maintenance practice.
Having metal chunks, however, is definetly a sign of larger problems.
SCCAGT is offline
Old 10-20-2008, 06:50 PM
ajaibr
ajaibr's Avatar
Preventative maintenance is one thing, 3000 to 5000 miles is just excessive though... Personally I've never even checked the level anywhere short of 50,000 miles....
ajaibr is offline
Quick Reply: Gear Oil Change?
