New CAI and don't know what to do!!!!!!
Old 03-12-2009, 09:05 PM
Ramtough5
Ramtough5's Avatar
Default New CAI and don't know what to do!!!!!!
I have a 2009 GT and purchased a CAI from UPR Products. I thought I would/ get it to the house and have it installed and increase my HP 25+ in less than 15 minutes like they advertised. Once the UPS man dropped it off and I opened it with much excitement, looked at the polished finish and ran to my GT with the box, I then set down by the tires and read the instructions. It read DO NOT INSTALL WITHOUT TUNING!!!!!!!!! Did I screw up by buying this brand? Do I have to take it to have someone tune it, before or after? Do I buy a predator or SCT tuner? Can I do it myself or is this beyond my capability? I want to put on some axelbacks after this, do I have to retune?
Ome more to add. Does this void my warranty? Is there a way to tune without the dealer knowing?
Ramtough5 is offline
Old 03-12-2009, 09:08 PM
winston44
winston44's Avatar
nothing better than the first mod!
install it...ive yet to get a tune for mine and it has the check engine light on because it thinks its getting to much air...tune it when you have time!
winston44 is offline
Old 03-12-2009, 09:12 PM
Ramtough5
Ramtough5's Avatar
How long and how many miles since you put yours on?
Old 03-12-2009, 09:26 PM
Nuke
Nuke's Avatar
CAI's require a tune unless the manufacturer states otherwise (and even then a tune is sometimes needed to prevent throwing codes). You should have done your homework first. There's a lot of info in the forum about CAI & tunes.
A few of the best tune suppliers are Brenspeed, Bamachips, VMP and Tillman. They'll provide you typically 3 custom tunes specific for your car along with the handheld. Running a CAI that requires a tune will cause you to run lean and is not good for the engine.
Also, a stand-alone CAI will net you maybe 5-8 RWHP if you're lucky. A CAI & tune combo will net you 15-25 + RWHP.
Nuke is offline
Old 03-12-2009, 09:29 PM
Ramtough5
Ramtough5's Avatar
Can I use one of these suppliers tuner with the CAI I have or do I have to buy a package deal?
Old 03-12-2009, 09:46 PM
157dB
Cut & Paste Expert
157dB's Avatar
Wrong, running a tune required CAI will cause the engine to run lean.
No so good. The cross section where the MAF mounts is bigger than
the stock intake and does not read the mass air flow properly.
A 'tune' takes care of this.
157dB is offline
Old 03-12-2009, 09:58 PM
Nuke
Nuke's Avatar
Most of the suppliers tunes will be "canned", i.e., a generic tune written to be used on most any car. These canned tunes are less aggressive and do not perform as well as a custom tune.
The vendors I listed above are excellent choices. They'll write custom tunes for your car specifically. They sell packages (CAI & tune combos) or just the handheld with the tunes preloaded. They'll also be able to e-mail you new tunes as needed to support tune-required mods.
Nuke is offline
Old 03-12-2009, 10:05 PM
foolio2k4
foolio2k4's Avatar
Wait WTF kind of CAI did you buy? brand? Go buy yourself a SCT tuner and your ok. Whether you use stock tunes or custom tunes. It'll allow you to use the CAI you have.
foolio2k4 is offline
Old 03-12-2009, 10:07 PM
blackice05
blackice05's Avatar
please ignore this advice, he obviously has no clue what he is doing.
Like stated contact a tuner like Bama or brenspeed and have them send you a tuner and 3 tunes. You will love it.
blackice05 is offline
Old 03-13-2009, 12:31 AM
stealth_GT
stealth_GT's Avatar
if the MAF housing is stock size, then it should be okay to run without a tune from what I hear, but with some of the other ones (85-90mm) you're gonna need a tune or you'll run lean and run like crap. The combo kicks ****.. I just returned mine to stock because i have to take it to the dealership for work and wow.. what a slug it is! fack!
stealth_GT is offline
FivePointToTheOh
10-02-2015 04:09 PM
algregory
09-11-2015 11:44 AM
Roush05
09-10-2015 12:23 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: New CAI and don't know what to do!!!!!!
