NEEDED whipple peice to complete install
Old 10-12-2009, 07:51 AM
hammeron
hammeron's Avatar
if you got rubber hose that is stiff and won't
collapse, you could use it between the PCV
valve and the elbow connection.
the brake vacuum line could be done the same way.
the tricky one is the hose between the EVAP canister
purge valve and the elbow. if you can replace that
section of tubing with hose and hose clamps, it should
be ok for very limited, temporary use.
hammeron is offline
djbigskrilla
09-20-2022 01:04 AM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
DannyBWell
08-29-2015 10:23 PM
defarmer
08-13-2015 06:40 AM
Quick Reply: NEEDED whipple peice to complete install
