Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-25-2009, 04:40 PM   #11
yellowjohn1
Vehicle: 2006 Ford Mustang GT
Quote:
Originally Posted by Jbauer View Post
the high levels of iron and the other wear metals are because you ran mobil 1.
Mobil 1 constantly has issues with showing wear metals on oil analysis when brands are switched. even alone, it has high levels of wear metals on analysis. It's a crap oil imo and i have no idea why its become so popular. It's the last oil i'd use on any car.
BTW: i'm surprsied blackstone didnt tell you this..they should know quite well that cars that ran Mobil 1 before show high levels of iron and wear metals when it is switched to another brand.
Can someone else comment on this statement? This is the first time I have ever heard anyone have anything bad to say about Mobil 1. If it is crap then what do you use? Just curious.
yellowjohn1 is offline   Reply With Quote
Old 10-25-2009, 04:57 PM   #12
jobeonnet
jobeonnet's Avatar
Vehicle: 2006
Heres a good oil study.
http://www.performanceoilnews.com/oi...nst_oils.shtml
__________________
2006 GT Prem Tungsten Grey
Brenspeed Tunes
18" Chrome Bullitts
Nitto 555 255/45-18
Steeda Ultralites
Tokico Dampners
J&M Camber Plates
Pypes H-pipe
If your not first... your last!
jobeonnet is offline   Reply With Quote
Old 10-25-2009, 06:43 PM   #13
Goldenpony
Goldenpony's Avatar
Just for the record, I want to submit a little more information. I began running Mobil 1 after a break in period of like 3K miles. I ran Mobil 1 5W20 until 40K miles. I ran (2) 5K mile cycles with the Amsoil 0W20 then began my 10K cycle at 50K miles, so this wasn't the first use of Amsoil after running Mobil 1.
__________________
2006 Premium GT Convertible
Screaming Yellow, Black Top
5 Speed
18" "Fanblade Wheels"
CORSA Performance exhaust
Brenspeed 93 octane tune
MGW Shifter
Goldenpony is offline   Reply With Quote
Old 10-25-2009, 07:35 PM   #14
bigray327
bigray327's Avatar
Quote:
Originally Posted by jobeonnet View Post
Summary: there ain't a damn thing wrong with Mobil 1 oil.
__________________
bigray327 is offline   Reply With Quote
Old 10-25-2009, 08:33 PM   #15
Jbauer
No , mobil 1 will alot of the times show high wear metals after switching oils.. its just the way its always been. i can prove this quite easily when the OP does another oil analysis.
i've seen UOAs by black stone in which Blackstone Labs actually tells recipients of the UOA that the high wear metals could be linked to the fact that they changed to another oil from Mobil 1.
M1doesnt look better than competition on many UOAs anyway...its over hyped.
i bet i can take a uoa on the Castrol edge im running now and a UOA on M1 right afterwards..im confident the m1 will have more wear metals..just from what ive seen.
i'll take back my statement..mobil 1 isnt crap...but it aint all its cracked up to be either. a lot of hard work went into making m1..its just that its overpriced and doesnt perform as well as its competition.. you want proof? go see UOAs on the same car..compare Mobil 1s wear metals to any other good oil..valvoline, castrol, redline, whatever..
Jbauer is offline   Reply With Quote
Old 10-25-2009, 08:42 PM   #16
jobeonnet
jobeonnet's Avatar
Vehicle: 2006
Quote:
Im with ya bigray, i run mobil 1. Prolly 75% of the people here run mobil one with no oil problems.
__________________
Brenspeed Tunes
18" Chrome Bullitts
Nitto 555 255/45-18
Steeda Ultralites
Tokico Dampners
J&M Camber Plates
Pypes H-pipe
Old 10-25-2009, 09:01 PM   #17
moosestang
Please stop the insanity! Did you read Goldenpony's statement above? This was his 3rd oil change using amsoil and 20k miles using it at that. You make absolutely no sense.
Where is an oil analysis of your car or are you all talk, spread BS you read, and no action? Did you look at my oil analysis? That's 24k miles using mobil 1 and 12k of it with a blower. Please post these blackstone labs comments you speak of. I'm positive you are taking something out of context.
I feel like i'm taking crazy pills! Mobil 1 is not some magic oil and it's not over hyped IMO. I switched to pennzoil this last change just to see if it lowered the copper/iron, but you want me to believe that it will only go up because of the oil I ran previously? Do you actually read what you type, maybe you're typing it backwards.
__________________
Boost or Buell, decisions, decisions.
whipple HO SC,FRPP springs, Pypes mid mufflers, hurst, 4.10's, J&M extreme joint lca's, adj. UCA, relo bracets, 1 piece DS, spec stg 2 clutch. Accel coils 12.52@117.6mph so far with a 2.01 60 ft time(pre shaft, coils, clutch).
Downshifting Crew Member
moosestang is offline   Reply With Quote
Old 10-25-2009, 10:12 PM   #18
Jbauer
hey bro , go pull some UOAs from bitog or something.
You guys can use what you want.. but Mobil 1 is over hyped and doesnt perform as well as the competition.
I understand you like mobil 1..and i respect that. but the fact of the matter is mobil 1 usually has higher wear metals..especially Iron. you can see this on most any UOA..heck go on BITOG and ask i'm sure you'll learn some stuff there.
I just dont like mobil 1..and many ppl are leaning away from it now..its overpriced and doesnt perform as well as most competition. You can use it if you like..i'm sure it wont cause your engine to blow up..but the UOAs you can find around the internet and even your own testing (do M1 and valvoline for 2 uoas after m1 and see what you get) will drive that point to you.
There will be no more arguing on this topic, understood?
Old 10-25-2009, 10:22 PM   #19
BruceH
2008 Ford Mustang
BruceH's Avatar
Vehicle: 2008 Mustang GT/CS
I would think the wear metals going up after changing from Mobil 1 would be because the new oil isn't working as well. What am I missing here?
__________________
2008 GT/CS 5 Speed
Control Arms, Prothane MM's
Aluminum DS, McLeod RST/Fidanza FW
FRPP Ceramic Shorties
FRPP Whipple HO 488/452 RWHP/TQ
Forged Rods and Pistons
Whipple Crew
BruceH is offline   Reply With Quote
Old 10-25-2009, 10:26 PM   #20
PSUSkier
Correct me if I'm wrong here, but wouldn't simply running a motor longer between changes just naturally mean higher wear metal contents? If you run an oil for an extra 5,000 miles and your engine wears at a rate of X particles per time period, you would expect to see more and it still be well within range. Just thinking out loud.
PSUSkier is offline   Reply With Quote
analysis, bench, bitog, blackstone, car, comparisons, filtration, high, iron, mobil, oil, read, report
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
