I decided to switch to Amsoil 0W20 oil and Amsoil filter. Amsoil claims this combo good for up to 25K miles. Anyway, I put it in at 50K miles. At 60K miles, I took an oil sample and sent it to Blackstone Labs. I just got the results. They said it had high levels of iron, aluminum and chrome and suggested going to a 5K mile cycle instead of 10K miles.
I will do just that until my current supply of Amsoil oil is gone and will switch to Pennzoil Platinum 5W20 and Motorcraft filter and change it at 5K miles. Lesson learned. Hope I didn't do too much damage.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Before I ran the Amsoil I ran Mobil 1 changed at 5K miles.
The test cost $22.50 with an extra $10 for a different test to test for additives, TBN test (The additives were still OK)). No, I didn't do a test with the Mobil 1.
I changed the oil at 60K miles and I will only leave it in for 5K miles this time.
I'm not overly concerned - I'm just glad I got the test kit. Now I know to change my maintenance plan.
the high levels of iron and the other wear metals are because you ran mobil 1.
I dont use amsoil..i would never spend that much money on oil and i think its foolish for anyone to do so; but even though i dont use amsoil and never ever will..im 99 percent sure if you do another intrevel with AMSoil...you will have results that are 5 times better.
Mobil 1 constantly has issues with showing wear metals on oil analysis when brands are switched. even alone, it has high levels of wear metals on analysis. It's a crap oil imo and i have no idea why its become so popular. It's the last oil i'd use on any car.
BTW: i'm surprsied blackstone didnt tell you this..they should know quite well that cars that ran Mobil 1 before show high levels of iron and wear metals when it is switched to another brand.
I always use full synthetic (after the motor is broken in) and I change the oil every 3,000 miles. I don't care if they say you can go longer, there's huge consequences for going too long between oil changes and no consequences at all for changing too often (except a little extra money). I've used castrol and mobil one and never had any performance issues and I beat on my cars, never had anything tested though.
I've torn down some of the motors in my old cars to do upgrades and the motors are super clean inside. between full synthetic and 93+ octane for the life of the motor when you take one apart the difference compared to cheap gas and cheap oil is obvious.
Vehicle: 02 Ford Mustang GT and 03 Crown Victoria PI
Quote:
So are you saying that anything over 3000 miles is to long?
__________________
2003 Grey Crown Victoria Police Interceptor the DD stock
2002 Silver Mustang Gt not stock
JLT Cold air intake
Accufab 75mm Throttle Body & Plenum
Mac longtube headers
Dr.Gas o/r x
SLP Loudmouth 1
3.73 gears
Steeda tri ax short shifter
H&R sport springs
Tokico HP Shocks & Shruts
18x9/18x10 Black chrome bullitt rims
SCT Xcal 2 tuner done by JMS Chip and perf. http://Centraltexasstangs.com
If the TBN numbers were good, the oil still had some life in it. You didn't really need to change it.
The heavy metals are there because of engine wear. By all accounts, Amsoil is as good as almost any other oil on the market. I wouldn't think that additional wear was caused by the Amsoil.
M1, OTOH, is not such a great oil. It tests out in the middle of the pack. I would blame the wear particles on the years of M1.
Where do you get the info on Mobil 1? I use it and would really like to see the test results on it. A comparison of most popular oils would really be nice if it exists.
The oil filter tests were an eye opener.
__________________
2008 GT/CS 5 Speed
Control Arms, Prothane MM's
Aluminum DS, McLeod RST/Fidanza FW
FRPP Ceramic Shorties
FRPP Whipple HO
That sounds like the biggest bunch of BS i've ever heard. Stop spreading FUD. Here's my oil analysis using mobil 1 5w30.
I don't drink the mobil 1 kool-aid and definitely not the Amsoil kool-aid. I changed to penzoil platinum and I guess when I do an oil analysis, my wear metals will be really high because I previously ran mobil 1. That makes no F'ning sense at all.
OP, post the oil analysis.
__________________
Boost or Buell, decisions, decisions.
whipple HO SC,FRPP springs, Pypes mid mufflers, hurst, 4.10's, J&M extreme joint lca's, adj. UCA, relo bracets, 1 piece DS, spec stg 2 clutch. Accel coils 12.52@117.6mph so far with a 2.01 60 ft time(pre shaft, coils, clutch).
