vortech winter woes...
Old 04-28-2010, 08:51 PM
stealth_GT
stealth_GT's Avatar
I wonder what the oil content for the supercharger is?? maybe I can add something to it to make it more durable during the winter and less prone to the cold conditions???
stealth_GT is offline
Old 04-30-2010, 09:44 AM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
That is B.S.
They should have made that info VERY clear before you purchased it if you ask me.
Then again if they did they might cut their sales down a crap load.
You would figure they would come out with some sort of kit or something for this issue themselves though.
Not doing that is just flat out lazy if you ask me.
Blacksmoke is offline
Old 04-30-2010, 10:37 AM
stealth_GT
stealth_GT's Avatar
Originally Posted by Blacksmoke
That is B.S.
Thats true. I read the install cover to cover for MONTHS before purchasing it, and only until I installed the kit and cleaning out the box did I notice the little envelope for the warranty and warning/maintence packet at the bottom of the huge box. If I had known about this issue, I would have went with the E-Force or supershaker.
From what I gathered, this kit should be okay because its self lubricated and not the externally lubed one. I almost went a step backwards thinking that if I converted it to externally lube and use an oil pan warmer would fix it.. not! Its because during cold weather, the oil is too thick and not flowing to the supercharger unit (external lubed,oil tap w/line) and on start up, theres no oil= boom!
Since mine already has oil in it, it should be okay. negative 25 is pretty friggin' cold anyways.. hasn't been that cold since the mid 90s up here, getting warmer actually. -10 is the coldest it's been...
Old 05-03-2010, 02:33 PM
OSUTX440
OSUTX440's Avatar
Ok, I live in Ohio, gets pretty cold in the winter, I had "0" problems with my V3 all winter. Now, I will say that when I have started it up when it was cold out, I let it run for a few before going. And lastly, I was rarely in boost, if you take it easy on the motor, the motor will take care of you.
I can't possibly imagine taking the S/C on and off every spring/fall....god that would suck.
OSUTX440 is offline
Old 05-03-2010, 03:19 PM
stealth_GT
stealth_GT's Avatar
lol the winter is the last of my worries at this point lol
Good to hear it's not an issue in the cold though..
Old 05-03-2010, 07:21 PM
REDBOSS1
REDBOSS1's Avatar
Is this just with the Vortech or does this happen with other superchargers as well? Just wanting to know because I'm in the market and just got an assignment to southwest Illinois and I know it gets cold there.
REDBOSS1 is offline
Old 05-04-2010, 10:43 AM
tx_zstang
tx_zstang's Avatar
How cold does it get where you are?
The issue with cold has more to do with mechanical clearances and less with the oil itself.
I never had any issues in the winter, but then again, it doesn't get that cold in this part of Texas in the winter.
tx_zstang is offline
Old 05-04-2010, 11:47 AM
stealth_GT
stealth_GT's Avatar
Unhappy
negative 10 up here in alaska..
Old 05-04-2010, 11:26 PM
tx_zstang
tx_zstang's Avatar
Yikes. How about a small heater for the vortech unit itself?
Old 05-05-2010, 02:14 AM
stealth_GT
stealth_GT's Avatar
ah fawk.. whhhhhhhhhhhhhhhhhhhyyyyy??!!
(O_o)?!
Quick Reply: vortech winter woes...
