Alternator and Crank bolt size for Steeda UDP?
I bought them used, and they were not included per the instructions on AM, I should use these bolts. Does anyone know the size of the two bolts?
http://www.americanmuscle.com/stunpusy2gt.html
Thanks,
David
Thanks,
David
The water pump pulley bolts are 10mm head. The crank pulley bolt is 18mm head. The water pump bolts are re-useable. I would advise getting a new crank pulley bolt, p/n F5RZ-6A340-B, due to the torque specification it uses. Get a quality impact type of socket for the crank pulley- it's a bear to loosen and tighten. Good luck.
Frank
Frank
Frank
Frank
For future search - Above part number is correct for crank bolt... Never reuse the crank bolt per every post I’ve read... spend the $8 bucks.. you will need a 3 prong jaw puller; no drill holes in factory crank. Taking the intake off is all that's necessary. Fan shroud and radiator removal is not necessary... Put some rtv on key hole and a little grease on the shaft... torque method 67 lbs - 1 full turn back - 37 lbs and 1/4 turn forward...
Alternator bolt is m8x1.25x55 MM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
11-09-2016 11:44 AM
NorthAmericanTuning
03-18-2016 11:21 AM
