Emissions inspection/Check Engine Light
Old 03-15-2012, 10:30 PM
JCON
JCON's Avatar
What is a riser?
And why I have I not heard of this before?
JCON is offline
Old 03-16-2012, 06:28 AM
S197GT07
S197GT07's Avatar
Originally Posted by JCON
What is a riser?
The only reason you get a code if you remove the cats is because all the rear o2's do is detect flow. To much flow = Cat problem. To little flow = Cat problem.
Since removing them will increase the flow, the "non foulers" pull the sensor out of the exhaust stream a bit, thus cutting the flow it senses.
S197GT07 is offline
Old 03-16-2012, 07:11 AM
JCON
JCON's Avatar
Thank you! I will be running test pipes initially and then high flows. Hope I'm good
JCON is offline
Old 03-16-2012, 08:03 AM
S197GT07
S197GT07's Avatar
Or you can get a tune, from a person who knows how to make it work.
No CATS here and I pass MA inspection
S197GT07 is offline
Old 03-16-2012, 04:37 PM
JCON
JCON's Avatar
Buying a custom dyno tune (and tuner) are not planned in the short term (this year). Here's to hoping I don't have engine lights
JCON is offline
Old 03-16-2012, 04:39 PM
S197GT07
S197GT07's Avatar
Guy thats local to me only charges $150, so it was kind of a no brainer.
S197GT07 is offline
Old 03-16-2012, 05:11 PM
JCON
JCON's Avatar
Only 1 dyno in my state, he charges $300 I believe
JCON is offline
Old 03-20-2012, 10:58 PM
cboisits
cboisits's Avatar
Default O2 Sensor Risers
I received the risers from Brenspeed today. But go figure! The "Check Engine Light" has not come back since Brenspeed walked me through the procedure of "reading and clearing DTC's" from my XCal2. I am going for inspection tomorrow for emissions only. Let's see what happens. And yes, they were only $19.99 for the pair.
cboisits is offline
djbigskrilla
09-20-2022 01:04 AM
J.casone400
08-28-2015 09:33 PM
kevans79@yahoo.com
08-18-2015 08:16 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: Emissions inspection/Check Engine Light
