View Poll Results: Which is the best option to reduse underhood temperatures on a supercharged 3V?
Ceramic-coated exhaust manifolds
22.22%
Ceramic-coated shorties
0%
Ceramic-coated long tube headers
33.33%
You're an idiot, Mike. None of this is worth the bother.
44.44%
Voters: 9. You may not vote on this poll
Underhood temperatures
Old 03-28-2012, 10:21 PM
JCON
JCON's Avatar
I nominate 908SSP for president.
JCON is offline
Old 03-28-2012, 10:38 PM
Young_Gun
Young_Gun's Avatar
I nominate Diabolical.
We have the beginning of the National MF'ing Party of the United States of America.
Young_Gun is offline
Old 03-29-2012, 12:08 AM
JCON
JCON's Avatar
We'll need members for Congress.. Young Gun, you're in for your state
JCON is offline
Old 03-29-2012, 05:32 AM
Young_Gun
Young_Gun's Avatar
Deal. Since the feds pretty much own GM, you'll be the new CEO. I say you start making 69 SS Vinyl Top Camaros again.
Old 03-29-2012, 07:15 AM
JCON
JCON's Avatar
Done. if the government is going to run GM might as well start producing cars people want.
On a side note, are we off topic?
JCON is offline
Old 03-29-2012, 07:21 AM
jdmcbride
jdmcbride's Avatar
Originally Posted by danzcool
From the thermal standpoint, I would think that ceramic coated exhaust manifold wold be best of the 3 options, whether you have headers or manifold they are all made out of iron, so that's about the same across the line, but the exhaust manifold has the least amount surface area in the engine bay, by having more surface area with the headers, you are letting more of the heat escape into the engin bay than out the back. That said, you may gain more performance with the headers than you lose with intake temps...
so you still may be an idiot... but ceramic coated is better than nothing.
Aftermarket headers (at least my JBA shorties) are made out of stainless steel, not iron.
http://www.americanmuscle.com/jba-sh...rs-0509gt.html
Since steel is stronger than iron, the headers are thinner and lighter than the OEM iron manifolds. The ceramic coating on the thinner steel insulates the engine bay and allows the heat to be transferred toward the rear of the car thus reducing the underhood temperatures. The much thinker and heavier iron manifolds soak up the heat and radiate it much like the old fashion radiators that used to heat houses/offices. A ceramic coating on the exterior of the iron manifolds might help a little, but you still have a heat sink that is heated up underneath the coating.
jdmcbride is offline
Old 03-29-2012, 10:31 AM
908ssp
908ssp's Avatar
Actually a good coater will coat the inside of the cast iron manifold as well as the outside. This keeps the heat away from the cast iron. In any case the surface area of a cast iron manifold is so much smaller unlike a old style house radiator which was made to have a large surface area. The tube headers surface is many time the surface area of cast iron. I will admit that when the engine is off the tube headers cool faster but again this indicates they give up their heat faster because of the greater surface area. In any case long tubes are a pain in the **** to put on and don't give you much in the way of real hp for the effort and expense. Their biggest advantage is the sound can't get that anywhere else but long tubes. $1000 for set of headers is nearly a third of they way to a SC which gives you some real hp.
908ssp is offline
Old 03-29-2012, 10:43 AM
jdmcbride
jdmcbride's Avatar
That's why I bought my ceramic coated JBA shorties for $329 when they were on sale...
Old 03-29-2012, 11:42 AM
Mathusula2
Mathusula2's Avatar
Hey guys, thanks for the replies. This is just one of the things I'm planning on doing for the sake of underhood temps. I'm installing a whipple on my GT (the 550 HP kit from Ford Racing) and I'm just trying to be as "safe" as humanly possible, as I know I'm pushing the limit of the stock short block. The other is to install small electric fans on the supercharger heat exchanger for additional cooling, so it's not my only mod, just one of many.
And not knowing any of you I'd still vote for you guys over the current lineup in Washington.
Mathusula2 is offline
Old 03-29-2012, 05:12 PM
JCON
JCON's Avatar
herehere!
Here's what I did, bought a like new condition set of Mac long tubes (actually mid length) and off road Mac ProChamber (with new gaskets and O2 extenders) on Criagslist for $300. Then I sent the barely used (no carbon build up or dings or scratches) headers to get ceramic coated for $140.
Total cost: $440 + $60 total shipping = $500
Shop around, it saves big bucks!
JCON is offline
Quick Reply: Underhood temperatures
