Car Problems, Sensor?
I have been having serious issues with my stang for the last year. Its a 2010 GT track pack. One if the first mods I did was a JLT CAI/SCT tuned by Brenspeed. After awhile of driving, the electronic throttle control light along with the check engine light would flash on and off. I took it to the dealer cleaned everthing, and anything I could think of, nothing was fixed.
I then bought a Steeda CAI, and got it tuned by Bama. The car ran perfect for 4 months, then started doing the same thing again. I cleaned the MAF and throttle body again, and it still runs terrible.
Also, when the electronic throttle control light comes on, the car loses half it power, and the runs dead like.
The code on my SCT for this problem is P2135 and the description is:
throttle/pedal position sensor/switch a/b voltage correlation.
Any thoughts on what the problem is, and how I can fix it? Much thanks is appreciated.
I'd take a look at the wiring to the TPS sensor to make sure it looks good. Make sure the TPS sensor clip is locked, that's a very common cause because the clip will wiggle lose.
If you check out the sensor, wiring to the sensor, etc. and it all looks good, then take a voltmeter, like suggested above, and let us know what it's at.
Has this car ever had an aftermarket throttle body on it?
I took off the CAI and TB and gave them and everything an extreme clean one last time, unplugged everything and replugged them, did any last detail, then reset the ECU.
Now the code is gone and the car runs fine..? But im not complaining! Maybe something wasn't plugged in all the way or something initially. I have the P1000 code, but thatll go away, so for now the car runs great, oddly, after all this trouble. If the cars keeps runs for next few weeks, Ill finally get my hands on some Kooks LT's! If not,ill check the voltage and the other suggestions.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
