New Underdrive pulleys causing missfire
Old 07-08-2013, 04:05 PM
wetwille3
wetwille3's Avatar
Default New Underdrive pulleys causing missfire
I just installed the Steeda UDP's, and I can feel smoother reving and it pulling a little better. But when I get on the highway (60 mph+) the car will eventually flash the check engine light and lose power.
I got the p0300 and p0304 code, which is a misfire. I have read through other forums, and the problem may be the crank pulley not properly tightened. I am not really sure though..I say this because im not sure if I tightened it properly..if so does anyone has advice how I should do it?
So, has anyone had this problem, and what should I do to fix it?
wetwille3 is offline
Old 07-08-2013, 09:04 PM
edwin108
edwin108's Avatar
Did you use a new crank bolt? The Ford shop manual outlines this procedure for tightening the bolt:
Stage 1: Tighten to 90 Nm (66 lb-ft).
Stage 2: Loosen 360 degrees.
Stage 3: Tighten to 50 Nm (37 lb-ft).
Stage 4: Tighten an additional 90 degrees.
edwin108 is offline
Old 07-09-2013, 10:40 AM
wetwille3
wetwille3's Avatar
The guide on this forums said not to, but a step by step video said to re use the crank bolt. I did re use it, because I couldnt get the new one in all the way (maybe i did something wrong?)
I attempted to tighten the bolt like you said, but again not sure if i did it 100% correctly. I may take it off and do it again..
Old 07-10-2013, 08:10 AM
edwin108
edwin108's Avatar
I think the bolt you couldn't get in all the way was the installer bolt. It's longer and only used to seat the pulley on the crankshaft (see step 13 here)
edwin108 is offline
Old 07-13-2013, 10:31 PM
04BlueGT
04BlueGT's Avatar
I had a similar issue with BBK aluminum pulleys on my '04. It was a balance issue that caused a vibration about 2700 rpm and tripped the code. Can't say it's the same with yours, though.
04BlueGT is offline
Old 07-14-2013, 07:03 PM
SpartaPerformance
SpartaPerformance's Avatar
Did you follow instructions? Hope you didn't use an impact gun.
SpartaPerformance is offline
Old 07-14-2013, 07:12 PM
clowe1965
clowe1965's Avatar
Yeah if you torque a bolt to a spec and then are told to turn it past that spec it is design to have the threads distorted so it is less likely to back out, one time use only though. Get it back apart and put the new bolt in before it blows up. If the issue comes back maybe the steeda rep can help you.
clowe1965 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
cr620
10-03-2022 10:18 PM
Thunderball
15
11-22-2015 11:49 PM
Dathan
10-05-2015 05:52 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: New Underdrive pulleys causing missfire
