Issues putting on mufflers
Old 01-31-2015, 10:29 AM
James07GT
James07GT's Avatar
Default Issues putting on mufflers
Can someone tell me why im having issues tightening the 13mm bolts to the hanger. Im new to this. I thought it was the bolts so I bought new ones but that didnt work. Im using a 13mm rachet wrench to tighten them.
James07GT is offline
Old 01-31-2015, 07:29 PM
jz78817
jz78817's Avatar
might help if you told us what mufflers you're putting on and what issues you're having.
jz78817 is offline
Old 01-31-2015, 11:26 PM
James07GT
James07GT's Avatar
pretty sure the muffler has nothing to do with it but im guessing its the flowmasters 40 series. The problem is Ive lost two hangers and 2 13mm bolts because they fell off while I was driving. Its because I cant tighten them with the rachet wrench I have. When I go over a bump they will fall off.
Old 02-01-2015, 07:55 AM
bstang14
bstang14's Avatar
Take a tip from a former Harley rider. Put no bolt or nut on without blue loctite. Having said that you need to be able to tighten it to begin with.
bstang14 is offline
Old 02-02-2015, 06:19 AM
Scott2
Scott2's Avatar
Does this illustrate the bolts you are having trouble with?
Have you tried tightening the bolts without the hangers in place, does this work? If not it sounds like the nuts inside the frame rails have been stripped. Stripping all four nuts is odd but I guess if an impact gun was used by someone not very careful, that could do it.
Hopefully others will have some ideas here, but you may need to drill and tap the "blind" nuts for larger diameter bolts.
Scott2 is offline
Old 02-02-2015, 10:58 AM
ghunt
ghunt's Avatar
Either the nuts in the frame are stripped, or you just aren't getting the bolts tight (your responses have been so vague I'm not sure).
I personally have found those bolts easiest to remove and install with a flex head ratcheting wrench. They're just too hard to get at with a regular ratchet.
ghunt is offline
Old 02-02-2015, 12:17 PM
James07GT
James07GT's Avatar
I think thats exactly what I need cause some of the bolts do vibrate when just standing still and when i go over bump can hear them sounds like they are loose.
Old 02-02-2015, 12:26 PM
James07GT
James07GT's Avatar
yes that pic is perfect. I was afraid that might be the case as ive had my mufflers put on by a shop. I have noticed two things though, one my hangers are worn out lol yours look new. Is there any difference between the steel ones and rubber ones. Second what bolts are you using they look different/better than the ones i'm using. If i can id like to avoid drilling. I havent tried putting them on without hanger.
Old 02-02-2015, 12:39 PM
James07GT
James07GT's Avatar
what flex head ratcheting wrench do you recommend? Lets say the nuts in the frame are stripped is there an easy fix?
Old 02-02-2015, 07:03 PM
jz78817
jz78817's Avatar
um, I did an axle-back on my 2010 (which is pretty much the same as the '05-09) and I didn't have the problems you're having. stop using box wrenches or ratchet wrenches and buy/borrow a real ratchet and set of sockets and extensions.
if the weld nuts were broken you wouldn't even be able to thread the bolts in.
jz78817 is offline
Quick Reply: Issues putting on mufflers
