Transmissions: Manual & Auto Tech
Old 06-27-2006, 12:48 PM
  #21
W1ldcat
W1ldcat's Avatar
Default RE: Transmissions: Manual & Auto Tech
4 + OD
W1ldcat is offline
Old 06-27-2006, 12:59 PM
  #22
P Zero
P Zero's Avatar
ORIGINAL: dtuna42
Questions for anyone who installed a higher speed torque converter:
What's normal drivability like?
What's best street stall speed with 3.73's but that will also help with racing?
What's involved in installation? And/or cost of installation?
Is anything else, besides the converter, needed to do the swap?
What kind of performance difference is there?!
Thanks!
Drivability - The trans will feel like its slipping until you reach its stall speed.
Stall speed - Its based more on your motor rather than your gear, for the street ideal is in the 2800-3500 stall speed.
Installation - Nothing special just the same as a regular torque convertor (always fill the convertor before hookin it up to the flexplate)
Performance - Its a great improvement over the stock one, it allows the trans to "slip" a little bit until it gets to a higher torque range, therefore you can get better launches and your car wont bog down in the low RPM's.
-P.
P Zero is offline
Old 07-09-2006, 07:01 AM
  #23
lynwood78
lynwood78's Avatar
When I'm about to reach a stop, my RPM's seems to bounce up a little bit. Is that normal when the car is tuned? It does it all the time.
lynwood78 is offline
Old 07-10-2006, 11:01 PM
  #24
jjsj38
jjsj38's Avatar
Question..........
Is it harmful to my automatic trans to be shifting it manually all time??
jjsj38 is offline
Old 07-13-2006, 12:43 PM
  #25
jjsj38
jjsj38's Avatar
does anyone know if you can damage your trans by upshifting manually??
jjsj38 is offline
Old 07-13-2006, 02:02 PM
  #26
retfr8flyr
retfr8flyr's Avatar
ORIGINAL: jjsj38
No damage.
retfr8flyr is offline
Old 07-22-2006, 12:59 AM
  #27
blackfoot
blackfoot's Avatar
ORIGINAL: Liam1694u
Auto Transmission question.
Already searched the forum and could not find an answer.
Ford advertises it as a 5-speed Automatic. From what i have found out about the transmission online, it seems to be a four speed transmission+OD.
(with the OD being the 5th gear).
So my question: Is the AutoTrans in the 05-06 Mustang?:
4-speed + OD
or
5-speed + OD
P.S. New to the forum, just bought a Legend Lime V6 + Pony Package on Friday. Extremely Happy
5th is overdrive, on teh conventional auto's 4th is OD.. ODjust means the gear ratio is that the car moves faster than the output of the motor.. typically 4th is 1:1 ratio on manuals. and 5th may be like .86:1 which is an overdrive, if you look at it your way. 5 speed manuals the 5th gear is an overdrive
btw welcome to the board
blackfoot is offline
Old 07-22-2006, 01:01 AM
  #28
blackfoot
blackfoot's Avatar
ORIGINAL: jjsj38
no but its a waste of your time, your car will shift faster and more efficiently before you could click it to the next gear.. those manual gears are there to say you towing a load and your going up a hill. click it to 2,1, or LO whatever it may be, youll get upthat hill alot easier
Old 07-22-2006, 01:03 AM
  #29
blackfoot
blackfoot's Avatar
ORIGINAL: StanG n StaLLioN
hey
possibility that any1 can answer this question for me??..ive gotta 06 mustang gt..auto trans..ive been lookin into converting my car to stick...i know the 06mustang GT uses a tremec tr-3650 5-speed manual transmission, but i havnt been able to see it bein sold at all..im also unaware if this idea of transmission conversion is gonna be possible with the model and year that my car is..can anyone give me any feedback on this idea? is it possible? if it is, i'd love for help and backup info on this.. thanx a lot guys
Black 06' GT
eibach spring lowering kit
18" maxxim rims
borla axle-backs
bbk shorty headers
bbk CAI
roush quarter window louvers
[IMG]local://upfiles/38041/4B642806079C4D40AA0D9DFF2715D1C3.jpg[/IMG]
check out your local ford parts.. your looking at probobly 3g's for the transmission.. and when you sell your automatic, it will make up for a good chunk of cash
Old 08-10-2006, 06:20 AM
  #30
TeflonDon
TeflonDon's Avatar
I have a question, are a stall converter and a torque converter the same thing? I have an auto gt with a diablo tune, I've been looking for a torque converter, but have no luck finding one online. Does anyone know where to get one? Also, the reason i was asking about the stall converter is, i want to get comp cams at https://www.rpmoutlet.com/musv8compcam.htm but for the stage III that i want they say i need at least a 2400+ stall converter and 3.73 gears. I have the 3.73 gears, but i have no clue what a stall converter is.
TeflonDon is offline
Quick Reply: Transmissions: Manual & Auto Tech
