4 cylinder handling
4 cylinder handling
I am currently researching low cost RWD cars with lots of handling potential. Since the Mustang is the only reasonably priced RWD platform since the 1980s it is at the top of my list. Right now I am looking to either a 1999-2004 v6 or a 1990-1993 5 speed 4 cylinder. Here is my question:
Can I get a reliable 120hp from a 2.3L with relatively inexpensive bolt ons? I plan to concentrate on handling by upgrading shocks, bushings and sway bars and possibly adding camber/caster plates to allow for more aggressive wheel alignment.
Anyone else out there who has put more into handling than hp? I would be very interested in all suggestions.
Ira
Ira
Unless you put a turbo 2.3 in, the handling might turn out to be the cheapest. Bigger cam, then port/polish to the max, CAI (if only to rid yourself of the stupid silencer), ranger header(or any tubular design) with full 2 1/4" exhaust without cats and a decent muffler, aluminum or carbon fiber driveshaft, and then a better fuel pump.
That might get you the 10-20 extra hp needed. Putting the car on a diet helps a little.
Suspension for fox body mustangs are everywhere so the prices are pretty cheap. $50 can get you a new set of sub-frame connectors. $400 for new springs and shocks.
The hardest part to find for the 2.3 will be engine mounts I think.
I am not really all that concerned about power, a smooth intake track, possibly a Ranger exhaust manifold and a good tune should at least keep it over 100hp. The frame stiffening and sway bars are more than likely my first steps, along with tossing any unnecessary bits to get the weight down. Fender flares and big tires (old school style on 15X8 or wider, wheels) will be the major concession to looks. This will be a cruiser with the possibility of the occasional (very) amateur slalom.
I just want a car that is fun to drive down a twisty road (and that I can afford to keep gasoline in at over $1 per liter).
Ira
Ira
Ira
