2.3 non-turbo question HELP!!!
I have an 88 2.3 that we race on an oval dirt track, we started with fuel injection and switched to carb that I did not like so we went back to fuel injection. Now the problem it won't run! we replaced the MAF sensor the computer, fuel pump, fuel filter, spark plugs. We have spark at the plug and coil but it won't fire. It started to run for us yesterday but after about twenty minutes in idle it will stall, also when it did run we couldn't rev it upbecause it would stall then. Please send any info or suggestions I will try anything right now.
RE: 2.3 non-turbo question HELP!!!
same problem with another car we had, except we didnt change it over to carb. then back again.
honestly we still havent figured it out. the car has sat in the yard for a few months. my dad believes its a censor, relay or short.
sorry i cant be more help.
ORIGINAL: ARdoller
88's didnt come with Mass Air
In california, they used MAF much earlier than the rest of the country, so you may have a california car. The 88 5.0's also got MAF in california.
Pull codes.
http://www.turbotbird.com/techinfo/R...stic_codes.htm
http://www.turbotbird.com/techinfo/eec.htm
That will allow you to at least get an idea of its a sensor related issue.
Pull codes.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
