The glow is because there is a tremendous amount of heat and pressure inside of that exhaust manifold. Youre ramming 2.3L worth of exhaust pressure through a hole thats about 2.25" in diameter. When the turbo spools up to 15psi, youre effectivly doubling the displacement of the engine, so then youre forcing 4.6L worth of air through that 2.25" hole.
Thats why turbo cars have much higher exhaust temps.
Oh Ya, They need to flow Exhaust out quicker to avoid Turbo Over Heating Problems. My Eclipse had a 3" to the Muffler than 4" Exhaust Tip.... BIG MOFO!
__________________
Jake Bastian
1985 Ford Mustang SVO
"If Work Was So Great, the Wealthy Would Keep It For Themselves"
My header gets really hot after little 10-15min drives.... but never red hot lol. I'll have to snap a shot of it with my phone.... but I have painted the header...
I have had that engine for almost 5 years and never seen it like that. Do you thing my cheap ass 3" high flow cat is clogged? I have 3" down pipe as well. My car is only set at 8 psi cause i lost the damn spring and ball in the boost valve
__________________
89 2.3 Turbo, 82 T-Top Notch 5.0, 86 LX T-Top 5.0 roller and 86 GT Black in and out with Gt 40X Heads, Smoothed Engine Bay, Battery in Trunk, SLP's, Bolt-on's
