4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
wont start after plug and wire change...
Old 12-08-2007, 02:31 PM
mustang_montana
mustang_montana's Avatar
Default wont start after plug and wire change...
firing order is 1,3,4,2 right? and cylinder one is the closest to the front so....what the hell happened here? all i did was change the wires and plugs, and now it wont start... is the firing order still wrong, or did the ignition module go on me...?
mustang_montana is offline
Old 12-08-2007, 03:54 PM
92lxsleeper
92lxsleeper's Avatar
Default RE: wont start after plug and wire change...
did you hook them on the distributor in the right spots.... i never had a distributor 2.3L, only EDIS system. i think #1 was closest to you and the right when looking at it.... not 100% positive though.
92lxsleeper is offline
Old 12-08-2007, 04:03 PM
sleeper_inc
sleeper_inc's Avatar
Was the egnie at TDC? and is your timing firing on the compression stroke or the other stroke(s)?
sleeper_inc is offline
Old 12-08-2007, 06:33 PM
damoney69
damoney69's Avatar
hah ignition module didnt go out...u probably put them in the wrong spots..if it turns over then ur fine just dick around with the wires til u get the right spots it ges 1 3 4 2 clock wise
damoney69 is offline
Old 12-08-2007, 06:47 PM
65coupe88hatch
65coupe88hatch's Avatar
i just changed my distributor and wires today..ill draw a pic of how the wiresshould be connected haha sorry for the crappy paint pic.
http://img471.imageshack.us/img471/3412/67369244ha1.jpg
65coupe88hatch is offline
Old 12-08-2007, 07:10 PM
damoney69
damoney69's Avatar
there hes is a diagram the circle isdistriband rectangle is yourcylinder
Old 12-08-2007, 08:41 PM
mustang_montana
yeah i was going by the chilton diagram, stupid me. turns out the diagram is wrong, all set now haha. thanks guys
Old 12-08-2007, 08:53 PM
damoney69
damoney69's Avatar
lol well i hope everything is good now!! i know mine is still dead
Old 12-08-2007, 08:58 PM
92lxsleeper
ORIGINAL: damoney69
The edis is WRONG!!!!!
Level, wheres the pic i drew u for the EDIS system, cause there is two ways, 91-92 had one way, and 93 had 3 and 1 reversed. find that pic and upload it here
Old 12-08-2007, 09:41 PM
damoney69
damoney69's Avatar
lol no its not wrong his is an 88 mine is an 89 its the same bro
Quick Reply: wont start after plug and wire change...
