Another No Starting Stang..any ideas? UPDATE 2
Hi all,
Well my 2.3 LX Stang has been great until today. I went to start her and she turns over but doesnt fire. I do not hear the fuel pump prime the system either. I checked the fuses and there all good.
Whats my next step? How do i hot wire the fuel pump to test that or how would i test the fuel pump relay.
Thanks guys
Thanks guys
RE: Another No Starting Stang..any ideas?
ORIGINAL: sleeper_inc
Hot wire the fuel pump and then check your timing bet
Thanks.
you wont hear the fuel pump kick on time after time. only when the pressure is low will it kick in.
Like said above, with the right amount of pressure the fuel pump wont even turn on untill the engine is started.
The timing BELT could have jumped a tooth from being loose or a bad tooth.
Thanks for the response sleeper. How would i jump the pump from the diagnostic connector? I do have a OBD1 scanner too that will check relays, so im assuming it will check the fuel pump relay too.
Thanks.
Thanks.
One thing i did also notice when trying to crank the car was that the tach needle bounces. I wont be able to hook up my scanner till wednesday to check that relay
