4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
1987 2.3 issue
Old 04-19-2009, 09:51 PM
fire1544
fire1544's Avatar
Default 1987 2.3 issue
hi guys i have a weird problem ny car has sat for a few months and i went to start it and it wont start. it is getting gas, and i replaced the plugs but still not starting any thoughts?
fire1544 is offline
Old 04-19-2009, 10:10 PM
dreamer1uk
dreamer1uk's Avatar
Hey,
Is your CEL on? And did you check to make sure your getting spark?
dreamer1uk is offline
Old 04-20-2009, 06:04 PM
fire1544
fire1544's Avatar
my cel is not on and i am getting fuel and spark. i just dont know where to check next. it is driving me crazy not driving the car
fire1544 is offline
Old 04-20-2009, 08:38 PM
dreamer1uk
dreamer1uk's Avatar
Hi,
Did you check your timing? and where in IL are you? Im south of Chicago here
Old 04-20-2009, 10:24 PM
edzdallas79
edzdallas79's Avatar
did you try using starter fluid to get it to start? if that still doesn't work, i'd check your timing.
edzdallas79 is offline
Old 04-22-2009, 01:29 AM
trashline
trashline's Avatar
How do you know your getting fuel and spark?
trashline is offline
Old 04-22-2009, 03:42 PM
92fordmustang
92fordmustang's Avatar
duhh, fuel has a purge valve on the fuel rail it looks like a tire valve, u poke it while the the car is on the on position and it should skirt up, spark, just take of a wire dat goes to a spark plug and check it
92fordmustang is offline
Old 04-22-2009, 10:08 PM
dreamer1uk
dreamer1uk's Avatar
Hi,
I think the above poster is refering to the Schrader Valve thats located on the fuel rail. The safest way to test for spark is using an Igniter/Spark Tester.
Old 04-22-2009, 10:38 PM
edzdallas79
Originally Posted by dreamer1uk
Hi,
yeah. and even doing that, he won't know if the fuel is getting to the cylinders or not. clogged injectors would be after the schrader valve. i wonder if he tried starter fluid like i suggested.
Old 04-23-2009, 02:15 PM
trashline
trashline's Avatar
WHOOOOO watch out for the super genius mechanic!!! F'in smart a$$.
Called covering your bases, as anybody with forum experience would know that.
Anyway back to the problem at hand. Starting fluid would be a good start. The problem is your not getting fuel or spark to the car for 90% of the no start situations. Could be a clogged fuel pump filter, bad fuel pump, bad fpr, bad dampner, bad injectors, clogged injectors. As stated spray some starting fluid, it if starts then dies then it is obviously fuel related. As for spark the TFI could be junk, the PIP could be junk, the dist gear could be missing teeth, or broken. Or the dist shaft could be broken. which was why I asked how he checked getting fuel and spark.
Quick Reply: 1987 2.3 issue
