mass air swap
turbo or non turbo?
Ford turbo
http://www.allfordmustangs.com/forum...onversion.html
For non turbo. I have not seen any writeup. But should be able to be done. Take the 8plug computer and MAF. Repin into a non-maf car. Then also the wiring to the ignition may need change because 8plug is dis and 4 plug is not. This should be able to be done. Since 2.3 turbo has had them changed from distributor to dis. Maurice
Ford turbo
what happened to the good old days when guys would rip out the efi crap and throw a carb on there. I say all emissions exempt four bangers should go out and buy an offy manifold and a pacesetter header and say f*** all that efi crap. A nice mallory distributor with mechanical advance, set the timing at 15* and go have fun
anyways, it can be done. just get the computer and repin the harness. look up the swap for the v8s, its almost identical
jaiidutch
09-14-2015 10:29 AM
panic
09-10-2015 05:56 PM
