4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Name that port
Old 08-26-2012, 02:31 PM
wgc68nyc
wgc68nyc's Avatar
Default Water temp port? (revised)
I am working on installing a second water temperature sender and I wanted to know if it is okay to remove this plug and install it here by the pump. I can't use the normal one as it sends high readings (feel free to offer a fix for that as well).
I am rigging up a switch with an Autometer gauge in the dash so I can go back and forth between trans temp and a more accurate water temp.
wgc68nyc is offline
Old 08-28-2012, 05:45 PM
mattdel
mattdel's Avatar
That plug is used for cooling system bleeding. The core unscrews from the plug and allows air out at the highest point in the system.
mattdel is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Dokilar
15
10-16-2015 08:13 PM
Urambo Tauro
10-05-2015 09:37 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: Name that port
