4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
Help needed
Old 02-09-2016, 07:10 PM
1ststangowner
1ststangowner's Avatar
Default Help needed
Hello guys, I'm work on you fiance's fist car ( 89 with a 2.3) and it has been sitting for 8 years. I dropped the tank, cleaned out the gas. I changed the spark plugs, wires, all the fluids and a new battery . I went to start it for the first time and is does not start. it has fuel pressure to the fuel rail. What direction should I go next?
1ststangowner is offline
Old 02-09-2016, 08:36 PM
jimkaray
jimkaray's Avatar
Spark. Did you shoot any starting fluid in her to see if it fires at all? Why was it sitting for 8yrs? Was it parked after it quit running? If it just up and died one day I would check the timing belt.
jimkaray is offline
Old 02-09-2016, 08:46 PM
1ststangowner
Thanks Jimkaray. I didn't think about that. I'll check it. I did use some starting fluid and it acted like it wanted to start but it did not. It ran when was parked.
Old 02-10-2016, 11:56 PM
1ststangowner
I checked the timing and it is on, belt is tight. Where should I go for here.
Old 02-11-2016, 01:25 AM
jimkaray
jimkaray's Avatar
Well, you still need spark. Check the wiring for signs of mice chewing the insulation. I would clean up all the ground points on the wiring harness, battery cable, coil, starter relay, etc...as they've probably oxidized. Test or try a new coil and ignition module if you have them.
jimkaray is offline
Old 02-11-2016, 10:22 AM
PNYXPRESS
PNYXPRESS's Avatar
Are the injectors spraying fuel? If its trying to start on starter fluid then its not a spark problem.
PNYXPRESS is offline
Old 02-12-2016, 12:30 AM
jimkaray
jimkaray's Avatar
Define "acted like it wanted to start" for us. Does it kick over and will run on starting fluid as long as you're spraying it? If so then its a fuel problem.
My interpretation of your description is that the starting fluid is trying to ignite off the engine compression, so its kicking somewhat like it might start but since there is no spark to light it up that's as far as it gets. If it is actually kicking over briefly on the spray and then dies out (unless you keep spraying) its starving for fuel.
One more thought since we don't know your level of experience. Are you trying to spray the starting fluid in front of the air filter? If so pull the filter so you getting a proper shot sucked into the engine. Have a helper crank the starter over while you spray short bursts into the intake.
jimkaray is offline
Old 04-06-2016, 02:37 AM
1ststangowner
I'm still struggling getting my 2.3L to start and I think I have found the issue. There is a connector coming from the fuel injector wiring harness that has a red and orange wires. it is not connected to anything.
I have been looking at wiring diagrams and I can not figure out where or what it goes to. can anyone help?
Jly154
12-28-2015 03:40 PM
Jly154
12-21-2015 12:11 PM
jrbdlb
12-07-2015 07:17 PM
Tali Weinstein
11-21-2015 12:06 PM
skinzy98
11-18-2015 10:23 AM
Quick Reply: Help needed
