4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
93 2.3 tach jumps and missing at 2500 rpms and up
Old 10-14-2016, 04:22 PM
zaillawson
zaillawson's Avatar
Question 93 2.3 tach jumps and missing at 2500 rpms and up
93 2.3 n/a mustang rag top. when under a load around 2500 tach jumps to 4000 and back and forward and starts to miss. Codes pulled are 62, 95 and 65. I have attempted to reset to verify codes. can not reset unplugged neg at battery for 30 mins, 12 hrs, then 4 days.
I have replaced plugs, wires, coils, ignition module and fuel and air filters. metered maf, relay box on fender wall {ircm} and tps all looks good. checked and cleaned air bypass and egr all is good. Checked voltage at fuel pump power 13.7 and ground is .1. Plan to replace crank sensor and check fuel pressure.
Any help or suggestions will be appreciated.
engine specs 86 turbo block with 2000 2.5 head with 93 stock edis has ran fine for past 20 months no codes no issues.
zaillawson is offline
Old 11-06-2016, 12:30 AM
zaillawson
zaillawson's Avatar
After 3 icm's came in bad and ford crank sensor also bad. Ordered a cheap crank sensor and with old icm car is running great
Brando
10-14-2020 03:44 PM
Redneck1465
07-07-2016 05:24 AM
puttputtt
07-04-2016 04:57 PM
PurpleJen5
03-17-2003 12:53 AM
pblossom
02-18-2003 04:06 AM
Quick Reply: 93 2.3 tach jumps and missing at 2500 rpms and up
